Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th September 2009, 07:16 AM   #1
Default DC-AC inverter using function generator + Mosfet + Transformer
Got a stupid idea, has anyone tried using a function generator or sine wave generator set to 50 or 60Hz, (powered by 12V battery, either DIY or off the shelf), pass through MOSFET for higher current, and step up transformer (eg. 12V to 110/230V) to achieve a pure sive wave DC-AC inverter, 110/230V...approx 1 to 3Arms?
Old 10th September 2009, 07:23 AM   #2
danzup is online now danzup  Romania
danzup's Avatar
Yes , a lot !
That have been done also with tube on 1940...1960 !!
Nothing new , nothing remain to be discovered ...
Old 10th September 2009, 07:30 AM   #3
any examples and circuit to show??
Old 10th September 2009, 02:07 PM   #4
Kurt von Kubik's Avatar
Send a message via MSN to Kurt von Kubik
Be aware!
This might be the lousiest way of powering audio equipment.
Noise is the problem, a DC/AC inverter creates thousands of times more noise than you will ever find in your wall outlet.
So if it isn´t for use far out in gods nature, try something else.
Old 10th September 2009, 02:21 PM   #5
Did it Himself
richie00boy's Avatar
I looked into it years ago and decided it was a total waste of time. Just use a car amplifier.
Kurt, what he wants to do won't have a noise problem as he's trying to use a low frequency sine wave not SMPS.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 10th September 2009, 03:46 PM   #6
yeah...i guess it's 50/60Hz supply, shouldn't have noise problem....isn't it?
And, possibly a project for 300Vac power supply for tube
richie00boy....why you said it's a waste of time?
Old 10th September 2009, 03:54 PM   #7
Did it Himself
Because you need a huge transformer and big powerful stage to drive it, together costing at least as much as another amplifier. If your aim is to run an amplifier, it's far better easier and cheaper to just use an automotive amplifier.
Old 10th September 2009, 04:07 PM   #8
sivan_and's Avatar
Send a message via Yahoo to sivan_and
WHAT A SHEAR WASTE OF ENERGY...this sort of linear converters in this age of GREEN power ?
SivanandBalan
Old 10th September 2009, 04:27 PM   #9
ajazz is offline ajazz  India
Yes it can be done !
Frequency Generator(XR2206) + Class D Amp(Naturally it's mosfet based) + Output boost Trafo = Pure sine wave (Green energy except for trafo losses)
Old 10th September 2009, 05:10 PM   #10
sivan_and's Avatar
this configuration is very old, u will find most of the UPS systems in INDIA using such configuration in inverter stage, the transformer is normal 50Hz type..uses mosfets / IGBT output stage...IR2110 in each arm in a bridge configuration
SivanandBalan
Function Generator? TheDriver Parts 4 18th August 2008 09:46 AM
Looking for an used function generator Eva Swap Meet 0 21st February 2008 06:56 AM
function generator d1camero Tubes / Valves 2 27th January 2008 06:26 AM
Have you seen my new function generator jwb Pass Labs 1 28th August 2002 06:06 AM
Page generated in 0.09150 seconds (87.72% PHP - 12.28% MySQL) with 10 queries
