diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   LiPO battery charging (http://www.diyaudio.com/forums/power-supplies/150472-lipo-battery-charging.html)
Atilla 31st August 2009 07:42 PM
I've seen different articles about using and charging LiPO batteries. I know exactly how to handle them in a normal design, but what I want to do this time is a little more demanding. In terms of space.
I want to simultaneously charge two iPod shuffle LiPO batteries from a 5V USB source, taking as little component space as possible. That means using as little parts as possible, going SMD and spending ages with a magnifying glass to do a p2p design, if needed.
I'm just not sure what thebest approach is, I've seen different discrete designs and various ICs that should take care of the whole process, but I don't really have any experience with Lithium batteries. Since the bloody things can catch fire, I'd rather get an opinion from someone that has played with those.
Any sources, ideas, anyone ?
By the way, I'm currently thinking that the MAX1555 is probably the best device for single-cell charging, but I've no experience with it yet, nor any ideas how to charge two cells at the same time over USB.
Atilla 2nd September 2009 11:38 AM
Actually, the MAX1555 is great for exactly what I want to do. I'll source a few of those, but I've got another dilemma on hand.
I want to use two cells in series, to get a higher voltage for an opamp. That shouldn't be a problem, but I need to charge the cells individually with 2 seperate ICs. I wonder how to wire that whole setup so I can accomplish that.
heinrichs 4th September 2009 05:37 AM
i would use some fets as switches so when i have to charge, they disconnect the load, and switch's the each cell to its own max1555..
maybe using a small C to do the switching.. or some simple logic.
Copyright 1999-2017 diyAudio
