#2 |
Hi, have a look there :
http://sjostromaudio.com/joomla/inde...d=46&Itemid=27 from PERANDERS. http://viller.eu/gb/images/pcb_rectifier.JPG from CVILLER. Both are DIYAUdio members. |
#3 |
Or use Schottkys and forget about the snubber
Have fun, Hannes
fresh matched IRFP240/IRFP9240 fets || AlephJ/JX-kitsF5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#5 |
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#6 |
Electrons are yellow and more is better!
The part you mention is a 35 A part and made out of plain diodes so I'm not sure what your point is?
/Per-Anders (my first name) or P-A as my friends call me |
#7 |
Well I don't know what use it is to put TO-220 diodes on a PCB, they won't ever dissipate more than a DO-204 in the same place. If you're going to use 10A diodes, the only way to actually *use* them is with a heatsink, which is why they put the tab on the things.
I must be missing something, did I just walk blindly into an audiophoolery product? As for snubbers, you can put RCs anywhere you like, either flying through the air or on another PCB. I'm surprised at all that there would actually be a *PCB* for *just a rectifier*, especially when it has 1/4" QC terminals just like the much cheaper, far more powerful product I linked to. Tim
#8 |
Keyword: schottky
ps: the link you provided was out of stock
#9 |
#10 |
Following Peter Daniel's lead, I'm going to make a bridge using individual "ultra soft" recovery ON Semi MSR 1560 (15A). But I'm not planning to use a heat sink, just connect to a terminal strip letting them just point into the air. It will replace the normal bridge in a 3-ch power amp. I should really get on that, so stay tuned for results in the next week or so. Hopefully the diodes will handle the heat.
| Page generated in 0.08443 seconds (85.32% PHP - 14.68% MySQL) with 9 queries |
