hi all
i need some help on connectors i am building a dac with separate power supply (separate boxes) i am looking for connectors (ideally circular) to connect the psu to the dac, it requires a 12 way connector i had a look at some industrial circular sockets & plugs in farnell but they are too expensive i.e £5 each which means about £20 in total so i thought i could use those cheap plastic ones which come with budget equipment (normally to secure the mains cable) and make my own cable by attaching 12 wires together. the connection in that case will be permanent the problem is i dont know how these connectors are called they are normally made out of rubbery material and you can bend them open to mount your cable in, and then once you push in the panel hole , it becomes tight and grips the cable very well. its some sort of clip-type any help will be appreciated thanks
"I don't remember fighting Godzilla, but that's probably what I would've done" |
#2 |
Those cable fixings are known as "Strain relief bushes"
Rapid do them Strain relief bushes Have a look at Cable glands too |
#3 |
Were you looking at 12 pin DIN connectors?
#4 |
awesome! thanks spiny
glowbug yes indeed. din connectors, they look nice but they are pricey
#5 |
problem solved i found these little beauties:
http://uk.farnell.com/jsp/search/pro...sp?sku=1193072 http://uk.farnell.com/jsp/search/pro...sp?sku=1321482
| Page generated in 0.07727 seconds (71.66% PHP - 28.34% MySQL) with 9 queries |
