Go Back   Home > Forums > Amplifiers > Power Supplies
Old 5th August 2009, 05:44 PM   #1
Default PFC voltage spikes
Hi again all.
I'm working on my first PFC and have finally got it to work (somewhat). The design is supposed to take input 85-265Vac and output 380Vdc. After much tinkering and trying understand how it works, I got it to turn on without blowing a fuse or a FET. My avg. voltage across my caps is about 390Vdc right now, but there are a lot of high frequency voltage spikes, sometimes registering on the voltmeter at over its limit (1000V ). On the o-scope, I see ~400Vpp max (ie. 600 V on cap during spike)
I zoomed in on the o-scope and found regular noise that lasts about 100ns at a time, and it's constantly happening, I'm guessing it's when the FET fires?
It freaks me out and I only have the thing on for a few seconds at a time, and I have a fuse and circuit breaker on the input. The time I left it on for about a minute, the inductor got up to 35C and the boost diode got up to 40C.
Since it's my first time, I don't know what's normal. I've looked around a lot and read a lot of application notes and guides, but haven't seen exactly what to expect. Do you guys see what's wrong with this? Or maybe that's normal? My caps are rated at 450V with surge rating of 500V :|
Here's the schematic. I haven't implemented the EMI portion yet.
Old 5th August 2009, 05:57 PM   #2
darkfenriz's Avatar
The schematic looks fine. You might like to add an RC snubber to a boost diode and RCD (or magnetic) snubber to the mosfet.
But first figurre out when particularly the spike happen, this can be body diode related as well. What's the mode? continous I guess?
Old 5th August 2009, 06:13 PM   #3
Yeah, it's continuous mode (although I'm not 100% sure what that means, that's what the IC datasheet says). Does the inductance of the boost inductor matter a lot in relation to the spikes? The same design aiming for 1/3 lower final wattage (300W) had 10x the inductance by my calculations - which didn't make a lot of sense to me :|
I'll watch the FET gates and see if that is related to the noise. I'm trying to learn about snubbers for my SMPS too, so once I understand how to design them, I'll put the on here...
Old 8th August 2009, 04:07 PM   #4
megajocke's Avatar
60EPS12
A 1200V 60A standard recovery diode as boost diode?
Old 9th August 2009, 09:10 PM   #5
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
If you have chosen that diode, you have to go a long way before you will be able to succeed. There are still many things to learn.
btw: The spikes that you see are just the huge electromagnetic interference resulting from hard switching with such a diode, the absence of EMI filtering and probably a bad layout.
I use to feel like the small child in The Emperor's New Clothes tale
Old 10th August 2009, 03:05 PM   #6
I know That's why I'm here...
Plus, I didn't "choose" this diode per se just the only one I had available with a high enough voltage rating to start testing. I have ordered a couple different ones (STPSC1006D, STPSC806D), but haven't put them into the circuit yet because they're expensive and my calculations show that I need ~15A rating, so I'd need 2+ in parallel...I don't know yet the additional things to consider when putting diodes in parallel.
It's good to know that one source of the problem is the diode Easy to fix, eh?
A couple questions:
-Does the EMI filter setup look correct?
-Do these diodes (STPSC1006D, STPSC806D) look like they'll work? I found a couple others with similar characteristics (C3D08060A, C3D10060A), but with a smaller leakage current...does that have an effect in this application?
-Board layout - still using a perf board, but will hopefully be doing a PCB this week! Any general suggestions welcome.
Old 10th August 2009, 03:33 PM   #7
Eva's Avatar
Great, these are Silicon Carbide diodes, they don't store any reverse recovery charge although they are expensive (recently introduced on the market). Using two in parallel is a good idea to be in the safe side, although one could probably do the job because duty cycle is low when current is high (120V input) and higher when current is lower (230V input). If peak current is always below 40A, do the RMS current calculation to know if it's below 18A (for STPSC1006D).
There are also much lower cost hyperfast diodes like 15ETX06 that store little charge at the expense of a higher forward voltage, and there are conventional ultrafast diodes like MUR1560 that store 1uC to 3uC typicallty.
For layout you have to visualize the loops in which HF current flows and minimize their area. A continuous ground plane over these loops also helps, it acts as a shorted turn for PCB track inductance.
For EMI filtering consider that output capacitors have some series inductance (1nH per mm of terminal spacing) and some ESR, and thus, there is going to be some output ripple that may require filtering depending on the kind of load.
Input inductor also has some capacitance, and input capacitor has some inductance. This means that some HF residual from switching waveform leaks through it to the input side, requiring additional filtering.
Also, output ground and input wires are not exactly at the same RF potential, some RF ripple is created across the PCB and the components. A common-mode filter fixes that by allowing one side to float at RF and coupling the other side to a 0V RF reference.
btw: Leakage current shouldn't be a problem as long as it does not produce substantial dissipation.
Old 10th August 2009, 04:08 PM   #8
darkfenriz's Avatar
Is it correct to interprete Qrr*fsw as a reverse DC current flow?
(sorry for off-topic and if it sound dumb)
Old 10th August 2009, 06:34 PM   #9
Eva's Avatar
Yes, but diode current is also flowing through the switch during reverse recovery time, so it's not an accurate way to predict switching losses. Actually, the current that was flowing through the diode has to stop flowing and start flowing through the switch at a di/dt rate, then reverse current starts to rise at a similar rate until the diode stops conducting. At higher diode currents, forcing a faster recovery usually results in less losses even if it's at the expense of a higher reverse peak current. Note that peak switch current is Id plus Irr.
Switch dissipation during the whole process is high, something like P=fsw*Vcc*.5*(Id+Irr)*Trr. The .5 factor accounts for the triangular current waveform. "Trr" has to include positive current fall time plus negative current build up time.
Voltage spikes under load tstitans Power Supplies 3 13th August 2009 02:01 AM
hydra spikes jamayfie Everything Else 0 19th September 2006 09:31 PM
to use spikes or not on T/L boxes busterno1 Multi-Way 4 4th January 2004 02:48 AM
Equipment spikes del Analogue Source 0 22nd July 2002 03:45 PM
Equipment spikes del Parts 0 22nd July 2002 03:43 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
