Hi guys.
I have an old 85 VAC center tapped transformer. I have no idea about it's power handling capabilities, but maybe it will help if I tell you that it used to power a mixer with two 200w class A amplifiers... Now, what I wish to know is: Can this be used to power up a Gainclone? Or perhaps two of them? Please help me about this one, I'm a bit short on money to buy a new transformer... |
#2 |
85Vac centre tapped will give ~+-60Vdc.
Enough to blow up as many chipamps you can throw at it.
regards Andrew T. |
#3 | |
If it's 85 V no-load you're not likely to get a real 200 watts. If you have 60 volt rails and figure about 3 volts drop (which might be optimistic) to the load, that gives you 57 volts peak or 40 volts RMS which is exactly 200 watts RMS into 8 ohms. But the rails will droop under load--probably by 5% - 10% depending on beefy the transformer is. So 180 watts is more likely. I don't think you really meant "Class A"? A true 200 watt two channel Class A amp would be a huge beast pumping out lots of heat. It would also need a really huge transformer and wheels to move it around ![]() If you want to know the approximate VA (volts*amps power) capability of your transformer the best estimate is to simply put it on a scale. Transformers are about 100 VA per kilogram. Or for pounds, divide the weight by 0.022 to get VA. It depends on who you ask, but a 400 watt (200 w/ch) Class A/B amp needs about a 600 VA transformer to deliver full power continuously into 8 ohms without the transformer getting too hot. You could get by with 350VA - 500VA for playing music into 8 ohms but if it's going to be used for demanding use you probably want 600 VA or more. If you want the amp to comfortably drive 4 ohm loads you want closer to 800 - 1200 VA. So it's hard to say how your transformer was sized for the old mixer it was in. Ideally the transformer should weigh at least 6 KG or or 13 pounds to be large enough for a 2 channel 180 - 200 watt amp. If you want less power than that, and don't want to use at least 4 (ideally 6 or more) output devices per channel than you probably want a lower voltage transformer like 30 + 30 or 35 + 35 VAC. So you can use your transformer and spend money on big heatsinks and output devices, or you can build a smaller amp and have to buy a new transformer |
#4 |
Well, now that you put it that way, it probably wasn't class A... But on the back of that mixer was written that it was 2 x 200w. And the transformer measures 85V under no load. About the weight, I'm not sure exactly how much it weights, but it's not very light... I'll put it on a scale tomorrow and post the results.
Anyway, what you are saying is that I am not able to use this one to power up, let's say, LM3886? So I have to buy a new transformer and/or some other devices? |
#5 | |
LME49810/LME49830 Power Amplifiers These days, if low cost is your goal, it's hard to beat commercial made in China products. That's true for DIY PCB amp modules and also true for finished commercial amps. For example: The Behringer A500 sells for under $200 US and it would be impossible to build a similar complete DIY amp in a rack chassis with similar performance for less money unless you already had a lot of the parts. Some people say bad things about the A500 but here's an objective review showing it performs fairly well: A500 Review But, yeah, if you're set on using the LM3886 you need a different power transformer. Another source might be a dead A/V receiver rated at 100watts/ch or less. |
#6 |
You can use voltage regulators to reduce the voltage.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#7 |
Or build a Leach amp:
http://users.ece.gatech.edu/~mleach/lowtim/ |
#8 | |
#9 |
I thought about voltage regulators, but there is a problem about them. I haven't seen simple regulators that can put out +-45V at high currents. I guess that the voltage regulator would be more expensive than the new transformer...
And the leach amp seems interesting... I'll look at it sometime soon... |
#10 | ||
| Using mains transformer as output transformer | Elias | Tubes / Valves | 175 | 3rd November 2009 09:36 PM |
| filament transformer vs plate transformer | contaxchen | Tubes / Valves | 10 | 14th January 2005 11:43 AM |
| toroid Transformer as power Transformer for tube | tone | Tubes / Valves | 7 | 11th February 2003 09:57 AM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 05:36 AM |
| Page generated in 0.12954 seconds (83.78% PHP - 16.22% MySQL) with 10 queries |
