#11 | |
In Class-D amps (not what we're talking about here) switching power supplies are more popular because the Class-D amp already needs filtering to get rid of the high frequency garbage from the power supply. But in a Class-B amp, like a gainclone, the noise on the power supply from a buck regulator would likely be a problem. It's also tricky to design high current, high voltage buck regulators. Most regulator chips don't meet the requirements. And the extremely wide range of load currents presents challenges with respect to sizing the inductor, minimum duty cycle, etc. |
#12 | |
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#13 | |
And many have demonstrated that even out of band HF energy can degrade the sound in various ways. And that still leaves cost, protection circuitry interfering, inductor saturation, lack of chips that can handle the voltages, etc. Switching regulators are the way to go for digital power supplies of 5 volts or less. But they really are *NOT* the way to go for a class-B audio power amp. There's fairly clear consensus on that. Do what you like with your own designs, but I'm trying to help zvir avoid a potential nightmare. |
#14 |
The easiest way is to center tap full wave rectify the transformer to get a single 60v output, then run a BTL from it.
| Using mains transformer as output transformer | Elias | Tubes / Valves | 175 | 3rd November 2009 09:36 PM |
| filament transformer vs plate transformer | contaxchen | Tubes / Valves | 10 | 14th January 2005 11:43 AM |
| toroid Transformer as power Transformer for tube | tone | Tubes / Valves | 7 | 11th February 2003 09:57 AM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 05:36 AM |
| Page generated in 0.08866 seconds (79.49% PHP - 20.51% MySQL) with 10 queries |
