Hi there...
I've been working on a project for an SMPS in the KW range for some months now and I keep running into different problems. Much research in books and online solved some of them, but I'm stuck now and I thought the expertise here might give some insight. I studied EE in college but most of it was in digital design, so power circuits is more self-taught. I've done some linear power supply design and also a lighter SMPS with simple topology, but this high power and different design has been a beast. I'm also working on a PFC stage which I will include (although I haven't gotten that to work yet...any input would be greatly appreciated if you get a chance). Any insight on my design is good. If you have a design example for this power range or a link to one, I'd be happy to try that, although I haven't found any through much searching. My application: Charging very large capacitors (.8 F x 3 in parallel) in a short time (<1s) up to 24 or 48V. To do that, I'd like to source up to 30-40A current. Here are my specs: Input voltage: 110Vac through a voltage doubler and rectifier (not shown), so 340 Vdc onto DC+ and DC- (as labeled on schematic) Output voltage: 24Vdc Max current: 40A My problem: I manage input Vac using a variac, and then either load it with an uncharged cap (~2000 uF) or a resistor 10R. Either way, when I increase input voltage to near the max (ie. normal US 110Vac), I start to blow the FETS. They are heatsinked and don't heat up too much, just suddenly I blow the fuse and testing shows that 1-4 of the FETs are now shorted on all 3 pins. I have a cheap o-scope can it's ground line is grounded to earth, so I can't watch what's happening between the gate transformers and my output (the voltage doubler sends DC- below 0 and sparks flew when I tried before I read the o-scope manual). I'm using a full-bridge topology with some modifications to improve the MOSFET switching and control noise on the gate. I don't know if those are causing problems. This includes the RC snubbers across the FETS and the transistor between the FET gate and source to drop Vgs quicker on the switch off (ie. bypass the transformer inductance) Thanks in advance! -Kevin PS. I know my schematic is all backwards...sry |
#2 |
Hi
You need an 1:1 isolation transformer ie floating for the DUT. The control loop/s... look at using current mode control (startup), and loop stability is key for large capacitive loads. You need to pick the right topology. Magnetic design and switching freq? Try lower power or lower freq first. Paralleling output rectifiers is problematic. Snubbers use 2 on the primary at the transformer not the fets. Snubbers across the output rectifiers. This stuff is very complex for a beginner. You need a lot of guidance or time to complete this project with any hope of success.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#3 | |
#4 |
Are you going to fed laser diodes with those capacitors?
I use to feel like the small child in The Emperor's New Clothes tale |
#5 |
It sounds like a spot welder application to me.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#6 |
infinia - thanks for the input. I'll keep working on it and see what I can do with modifying the design.
It is for a spot welding device, which I know isn't audio, but the high power needed made this a good forum in my mind. The high capacitance is for high energy in a short discharge, which ends up being many times more amps than an SMPS could do. As for the laser diodes - not sure what to do with that, I haven't run into it before. I know it's a tough project, we'll see how it goes. Thanks for the help! |
#7 |
I asked because professional epilation lasers based in 808nm LEDs use 48V too, and up to 150A pulses, and the capacitor bank method too. These are stacks of massive water-cooled LEDs, not a joke
#8 | |
You need to either use a large set of caps or a set of "pulse" capacitors (Big $$$) that are designed for large current pulses. Super caps are not designed for Pulse discharging. BTW when the capacitors fail, the go out with a flash and a bang. When the foil vaporizes it creates rapid high pressures inside of the can causing the can to fire up at rapid velocity (enough to knock you out if it cap is large in size). The foil has a 50% of bursting into flames and the caustic electrolytic can cause chemical burns if it sprays on your skin. Have fire extinguisher handy, and wear eye protection when you test. The best way to charge a cap bank is with a current limiting power supply that limits the amount of power. One simple option is to place an AC cap in series with the transformer primary. The Cap will limit the amount of current on each half cycle. The cap does not need to be large and you can increase the current load by increasing the switch frequency even if the cap has a fixed capacitance. A more complex method is to use PWM current control starting off with a very low duty cycle and increasing the duty cycle as the caps near full charge. You could either do this on the primary side or as an additional circuit on the secondary side. You can also use SMPS controllers with built-in current limiting. They usually use a current sensing resistor to monitor the current. |
#9 |
Hi TechGuy
Good catch about using banks of pulse caps instead of 3 super caps. A supply like this is going to have to use current mode control for sure. The best way to sense current esp big converters is using a current transformer. ( too much common mode and layout problems with using a resistor.) AFAIK An AC cap in series with the primary does nothing to limit current in a pulse to pulse basis. It's used to balance voltseconds to prevent the saturation of a (half bridge)transformer core due to non symetrical pulses over many cycles.
#10 |
What about use a bank of higher voltage capacitors and a high frequency transformer driven by an IGBT bridge to step down the voltage? Spot welding doesn't care if it's AC or DC, so the secondary winding can just directly connect to the electrodes.
| What about FETs for Cellular Base Stations in Audio Cascode Voltage Gain Stage (line | tiefbassuebertr | Solid State | 8 | 23rd August 2009 02:53 AM |
| power supply fets keep blowing | Clipped | Car Audio | 23 | 22nd January 2006 06:48 AM |
| SMPS - Why are my FETs cooking? | Bosium | Car Audio | 42 | 17th August 2005 03:13 PM |
| high voltage fets | kaukasion | Solid State | 11 | 25th December 2003 06:20 PM |
| Page generated in 0.12538 seconds (79.40% PHP - 20.60% MySQL) with 11 queries |
