diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   Smps 220vac / 13.8vcc For 100a (http://www.diyaudio.com/forums/power-supplies/146969-smps-220vac-13-8vcc-100a.html)
albert_emule 4th July 2009 06:25 PM
Hi everybody!
I want to make a power supply for my car audio system. For this, I need a 1.400W supply with 220Vac in and 13.8Vdc out 100A.
If anyone help me, I apreciate.
the pcb layout that was concebibo for symmetrical SMPS, being able to be 1 only:
http://img133.imageshack.us/img133/2966/placaprota.jpg
these photos, it is the toroides what I am using in the project:
http://img27.imageshack.us/img27/7297/dsc01240g.jpg
http://img89.imageshack.us/img89/5820/dsc01241x.jpg
http://img39.imageshack.us/img39/6488/dsc01242y.jpg
this one here, it is the schematic of the SMPS:
http://img17.imageshack.us/img17/4180/fullbridge.png
Thanks.
Bootstrapper 4th July 2009 06:31 PM
Pulling 100 A current out of the converter requires much thinking! For example the transformer windings will be very huge - even that leads to a large core. From your pictures it looked like the windings would not fit to your core. Do the calculations!
albert_emule 4th July 2009 06:46 PM
that not atija 100A, I want that it reaches the biggest current, which will be able with this toroide
albert_emule 4th July 2009 06:55 PM
what is the number of turns of the primary enrrolamento and the number of turns of the secondary enrrolamento, for this nucleus?
how must I proceed in the calculations?
Thanks.
star882 5th July 2009 03:48 AM
Open up the amp and find out what internal rail voltages it uses. Then build a power supply that outputs those voltages directly.
odnaizutra 11th July 2009 04:10 PM
hi Albert,how is your project?
As i m new in the block ,im thinking about beggin my project in half bridge using igbt +2110+3525 as initial form.Voltage controled regulated power supply.Im about using n27 toroid as main trafo and searching about output inductor,mainly because i will use high bank capacitance.
Have closed the regulation loop already?
Eva 11th July 2009 07:11 PM
You should avoid toroid SMPS transformers for offline applications. Proper insulation is hard to achieve and usually ends up degrading transformer performance well below the level of E cores.
Or you may do like that forum member that we know who sells a product where primary mains-live magnet wires touch directly with secondary wires.
A little scratch on the enamel and someone may end up injured or dead.
albert_emule 13th July 2009 01:45 AM
my SMPS is with 20A in 112vac, and 50A in 14.74VCC
WHAT CAN BE CAUSING THIS LOW PROFIT?
Eva 13th July 2009 07:21 AM
A calibrated power meter is required for efficiency measurements like that. Better than 1% precision is required.
Input current is a complex waveform, the current reading from a conventional multimeter is useless.
albert_emule 13th July 2009 09:43 AM
a voltmeter TRUE RMS, is it sufficient to meter the efficiency of the SMPS?
Resources saved on this page: MySQL 18.75%
