#31 | |
#32 | |
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#33 | |
just try winding the required length of thick wire on to a long bobbin to feed through the middle of the toroid. Now, try to feed that bobbin through and around the toroid core and try to place that thick wire in neat parallel lays without any kinks. I suspect the machines that wind toroids have a similar problem getting sufficient tension to straighten out the thick wire. I can wind 1.6mm (6A) wire but 2mm (9A) is almost impossible for my hands. We are working at 50/60Hz. Skin effect is a non starter at these low frequencies. In fact the opposite is an advantage. Thick wire will help attenuate the HF interference that comes in from the mains. If the winders could use very thick wire in the higher VA toroids it would remove one of the disadvantages of a toroid cf. EI types. |
#34 |
Right, I can imagine the physical difficulty. But one is usually winding on just a few extra volts, so maybe 10-15 extra windings with whatever fat-ish wire one has available. In my case it has been stranded wire, so not a problem physically.
| 0-30v 0-10a PowerSupply | gev | Power Supplies | 16 | 24th May 2006 08:06 PM |
| PC PowerSupply | gev | Power Supplies | 0 | 24th July 2005 01:00 PM |
| DC powersupply +-15V 2-3A | JensRasmussen | Solid State | 9 | 22nd February 2004 09:42 PM |
| Powersupply | Kongen | Solid State | 4 | 26th October 2003 03:19 PM |
| Page generated in 0.49697 seconds (100.00% PHP - 0% MySQL) with 9 queries |
