Hello
i was just wondering, if anybody is using 2x batteri packs, to power ur preamp/dac or anything else low power? my ideer is to charge one battery pack, and use the other. and then switch when you have to. could be made quite easy with some li-poly cells.. like these http://www.robotmarketplace.com/prod...s_e_flite.html using this IC to charge each cell individualy http://www.maxim-ic.com/quick_view2.cfm/qv_pk/2536 and some relay's or some fet switches, to control what pack is in use, and which is charging. ofcourse you would also need a capacitor to so you dont loose power when you switch, some simple regulators.. and a µC to control it all or maybe using 2 banks of double layer caps, somethinh like these. http://dk.farnell.com/jsp/search/pro...questid=179128 then u wouldn't have the lifetime problem of the batteries. and wouldnt have to use the speciel charge IC's wouldn't a setup like this, remove almost any noise on the power supply? or is it just a stupid ideer, form another newb? |
#2 |
It's pointless. There are regulator circuits designed for instrumentation that are about as pure a supply that is available.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#3 |
I used 2 x 12VDC Gel batteries to produce +/- 12V for my DC preamp. They are a fantastic, noise free source of DC for audio. No chance of ground-loops either!
I use a DPST power switch that directs the batteries to the audio circuit when 'ON' and when 'OFF,' the batteries are connected to the charger jack. You may be able to do something similar with a DPDT, center-off switch where center is off, one position is operating off battery A and charging battery B, then when in the other switch position, it will be operating off battery B and charging A. Just an idea. Anybody can use AC power and regulators. I say go for it and experiment away and have fun! Cheers, Paul
"Believers cling to the myth despite the evidence, reinterpret the myth to suit the evidence, or lie about the evidence to support the myth." "To err is human; to blame errors on external factors is even more so." |
#4 |
Hi DCPreamp,
Sorry for my ignorance but what does "DPST" stand for? If I understand well you use a standard battery charger. If I may ask did you compare your preamp with AC regulated sypply and with battery regulated supply? What was the impression? I just tried that on my circuit http://www.diyaudio.com/forums/showt...19#post1883719 Cheers, cdfr |
#5 |
DPST- Dual Pole single Throw
#6 |
@star
hmm you are proberly right, though i still think i will do it in my comming preamp.. since i already have the design for it, and i dont have much knowledge on regulators... @dc if i do it, the switch between what batteri in use and what is charging, would happen automatically using a small circuit i used in a solerpowered robot... but it was just a thought, and since the circuit is quite simpel (though there are some pretty small smd's..) and the only drawback i could see being the cost of it.. i just wanted to share the ideer, since diy'ers have a habbit to overdo things (in my experience atleast.) |
#7 | |||
Since my batteries are in series, I use the 24VDC charger. I got mine off eBay for about $20. Quote:
I hope this gives you some direction. Paul
#8 | |
Enjoy, Paul
| how do i charge a capacitor? | Infinity_Addict | Car Audio | 18 | 30th August 2010 08:26 AM |
| portable batterie powered amp (2x 2W) ??? | Artemus GF | Class D | 6 | 9th July 2008 10:41 AM |
| charge pump | jamesrnz | Power Supplies | 0 | 8th July 2008 12:23 AM |
| trickle charge psu? | nafunga | Tubes / Valves | 6 | 19th December 2005 02:00 AM |
| Batterie powerd Pearl, Questions | Dr. ODD | Pass Labs | 10 | 30th December 2003 02:49 PM |
| Page generated in 0.11180 seconds (80.98% PHP - 19.02% MySQL) with 10 queries |
