Going from 35V to 18V is a 17V drop. If you want to draw even a measly 200mA, you'll dissipate 3.4W. Maybe that's ok, but the suggestion of a switching buck regulator is a very good one if you need any significant amount of current. There's a reason you'll almost never find a shunt regulator in commercial equipment (non-audio) other than as a voltage reference- they're a bad choice in almost any imaginable application.
Conrad Hoffman said:There's a reason you'll almost never find a shunt regulator in commercial equipment (non-audio) other than as a voltage reference- they're a bad choice in almost any imaginable application.
Except to save yourself warm in upstate NY winters.
don't know...frankly speaking, I was to lazy to search for a translation.pacificblue said:Is "grummel" the correct English translation of the same word in German?
But it should be quite self-explanatory.
And yes, it is bad practice to feed that poor reg with 42V and should be avoided in educational publications even if the part survives.
regards
purpf said:I'm thinking of using a 2x24v toroidal core transformer with 2 PS units. 1 PSU to power an LM3875 chip amp and the other to power a preamp. Unless I can find a preamp powered by ~35v, I need to lover the voltage to about 18v.
The normal solution is a a third winding on the transformer, two secondaries.
I 've got the same problem with an amp I want to build. The power transformers I have is 481V and I need 320V. Dropping 160V with a resistor is not going to work. I'll just have to buy another transformer and save my big 481V transformers for another project.
Tube amp!acid_k2 said:OT (@ ChrisA)
320Vdc is about 1500W rms @ 8 ohm. Are you sure?
- Power Supplies
- 35v to 18v
