Hello
I've received, for free, a defective Motomaster Eliminator 1750 watt power inverter. The circuit use a SG3525. It seem to be made by Xantrex and I can not find any schematic of this inverter. Four of the IRF640 output mosfets are burned. I presume that those four mosfets was connected in parallel, and one mosfet did goes unbalanced and have to much load and burned, after that the 3 others get all the load and burned ? I can replaced the 4 burned mosfet, but I was thinking to put a .1 ohm resistor on each source terminal of all the 16 output mosfet for a better current sharing between all those mosfet, is it a good ideas ? Thank Bye Gaetan ![]() ![]()
#2 |
Do not try to reengineer it without understanding it first.
Power the inverter with a current limited supply for initial testing. If nothing else, connect a car light bulb in series. Make sure none of the components are heating up. It is possible that another component is bad which caused the MOSFETs to burn out, but it can also be caused by an overload, incorrect input voltage, or overheating.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#3 |
This looks like a quasi-sine inverter and these blow quite easily because they always have trouble with big inrush currents and very reactive loads like motors. In most cases the MOSFET drive circuit is too simple to suffer damage and replacing the MOSFET is enough.
You should check that the drive circuit works and that the rest of the MOSFET are not damaged, though.
I use to feel like the small child in The Emperor's New Clothes tale |
#4 |
My dear friend you've not told us the details about the input transistors since from my view it seems to be employing smps and also informatio about those other ic's beeing shown in your photo.
Thus try to give adetailled information of other components. |
#5 |
#6 |
Hello
I have talk to the guy who did have this inverter before me. He told me that, by error, he plug a live 120 volt ac wire into the output plug of the inverter. Thank Bye Gaetan |
#7 |
Because that would require an extension cord with male plugs on both ends. What was he trying to do, hook up a solar or wind generator to the house electrical system? If that's what he's thinking, it needs to be a true sinewave inverter and synchronized to the power line. Otherwise, BANG!!!! Ought to thank his lucky stars that he just blew a couple hexfets.
#8 |
I think he was trying to make a large UPS with the inverter. With his dangerously limited engineering skills, he probably thought that by connecting two sources in parallel, he can lose one and still have the load powered. Of course, although that will work to an extent with certain DC sources, it generally won't work with AC.
#9 |
Hello
The first time I ask the guy it was quite short answer, so today I did phone again Robert, the guy who burn this inverter, he told me that he was using it in a big fifth-weel RV for camping, normally he do unplug the inverter from the 120volt system of the RV , before connecting the RV to the 120volt system of the camping. He just forgot to unplug the inverter wen he did plug the RV to the 120volt system of the camping. So it was just a plain forgetfulness from the guy. I presume and hope that only the mosfet are burned, so soon I can have some IRF640, I will replace them. Thank Bye Gaetan |
#10 |
Remove the bad MOSFETs and try to run it. You should be able to measure about 170v on some of the large capacitors inside it.
| Power Inverter help | lljohnll | Power Supplies | 14 | 16th December 2009 05:44 AM |
| About a PWM power inverter | gaetan8888 | Power Supplies | 5 | 12th March 2009 12:27 AM |
| power inverter | rtill | Everything Else | 1 | 27th February 2009 11:15 AM |
| power inverter | Kelloggrice | Parts | 1 | 8th June 2007 07:44 PM |
| Inverter as a power source | orac02 | Power Supplies | 21 | 12th April 2007 06:57 AM |
| Page generated in 0.11206 seconds (77.88% PHP - 22.12% MySQL) with 11 queries |
