Go Back   Home > Forums > Amplifiers > Power Supplies
Old 17th June 2009, 10:37 PM   #1
Default Bench supply?
Please move me if i'm in the wrong section....
Does anyone know of any decent bench supply designs. I've been working on a few car amplifiers lately.
So i need possibly 40/50a @12v, so +ve and ground will be fine, ideally a remote (12v with just a switch) wil be perfect too.
So far i have tried a 12v battery with a charger across it, but i keep tripping the charger as it can't supply more than 4a @14.4v.
Then i tried a PC PSU whih drops to 11.5v, then cuts out if drawing anymore than 10amps.
However that wont even turn on sometimes if it detects conductivity from the +ve to the -ve terminal.
Old 17th June 2009, 11:53 PM   #2
Something like this http://www.maplin.co.uk/Module.aspx?ModuleNo=30391
But fixed at 13.8v.
Old 18th June 2009, 12:06 AM   #3
star882 is offline star882  United States
star882's Avatar
http://www.qsl.net/xq2fod/Electron/PS40/PS40.html
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 18th June 2009, 12:20 AM   #4
sandyK is offline sandyK  Australia
Default Bench Supply
Something like this ?
http://www.jaycar.com.au/productView...y&form=KEYWORD
CAT. NO. MP3089 RRP $199.00
CLICK TO ENLARGE
13.8V 40A Switchmode Laboratory Power Supply
A high powered 13.8V switchmode power supply delivering up to 40 A and suitable for use in development and test environments. The internal cooling fan will assist cooling at higher outputs and the unit has easy to use 4 mm banana connectors.
Specifications:
Input voltage range: 190 - 240V AC
Output voltage range: 13.8V DC regulated
Output current rating: 0 - 40amp
Output connections: 4mm Banana/Clamp Type
Recommended Fuse: M205 T4amp
Measures: 80 (H) x 117 (W) x 119 (D)
QTY
1+ $199.00
3+ $178.95
6+ $158.95
Old 18th June 2009, 12:30 AM   #5
Thanks star882, sandyK i was looking at something for a summer project, to have a go at building.
+/- bench supply ideas.. DigitalJunkie Power Supplies 8 3rd January 2007 08:51 PM
Bench Supply jonclancy Parts 4 22nd September 2004 05:36 PM
My new bench power supply Circlotron Equipment & Tools 7 28th April 2003 04:29 PM
bench power supply jethari Parts 1 14th March 2003 06:31 PM
My bench power supply.. deepanger Solid State 71 18th February 2003 08:56 PM
Page generated in 0.09457 seconds (70.63% PHP - 29.37% MySQL) with 10 queries
