Go Back   Home > Forums > Amplifiers > Power Supplies
Old 15th June 2009, 11:51 AM   #1
Default positive and dual power from LM675
I have a smps of +18V 3.5A and want to put it to good use. I have a Class D amp (TPA3121) needing a +18v supply. The amp needs balanced input, so I have a DRV134 and a buffer needing dual supply. +/-9v is not ideal but this can be used to test the circuit. Is there a way to provide +18v and +/-9v at the same time? I looked at LM675 datasheet. It seems that you can have +/-9v from +18v, but the GND will be lifted. How would I obtain another +18v? How are the grounds connected?
Cheers.
Combining two positive regulated suppiles for obtaining a a dual one Atilla Power Supplies 9 30th July 2009 10:49 PM
Noob Question: Hooking up 2 positive Linear power supplies for +- output? hifimaker Parts 1 16th March 2007 12:57 AM
Parallel a dual power supply or two power supplies? Thunau Power Supplies 12 16th February 2007 04:21 AM
LM675,worth to try or not??? Leolabs Chip Amps 3 6th December 2006 04:08 AM
diy dual lab power supply morpheus82 Power Supplies 25 10th July 2006 12:41 AM
Page generated in 0.06254 seconds (77.78% PHP - 22.22% MySQL) with 10 queries
