I am building a soft start module from avondale audio... however the board didnt come with part specifics and I dont knowenought about each part (well a few I do) to competenlypick them out. Could I get some help from the knowledge base here? ATtached is the board layout.
#2 |
I see.....
4x 10nF capacitors (ceramics?) 1x 220nF X rated fim capacitor 2x 470uF 35V electrolytic capacitor 1x 100uF 35V electrolytic capacitor 3x 10R 7W resistors 1x 220R 2W resistor 1x 800K-1M resistor (>1/4W?) 2x 24V zener diodes 2x 24V 10A relays 1x 1A 1000V bridge rectifier I see there are some hand drawn notes that aren't fully visible pointing to the 220nF cap and the 10R resistors. The board on Avondales website shows a MOV (metal oxide varistor) to the right of one of the 470uF caps and it has 6R8 resistors instead of 10R. http://avondaleaudio.com/audiophile-...-start-module/
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#3 |
yeah the hand notes are for the large 10R resistors that states for the US version to use 4.7 Ohm instead and the other note points to the 220nf X rated cap and states "Series capacitor 1uF" ...
I am confused on what part to get for the relays... digikey gives you so many options for them I dont know where to begin... Anything special for the bridge rectifier? and what is a x-rated cap... I think its a UL rating for flame retardation correct? I wish they would have supplied a BOM (I asked them for one and they really wouldnt supply me with one...) thanks for your help! what you see is all the info I got for 10GPB a board... |
#4 |
For the bridge rectifier I got digikey part number W10G-E4/51GI-ND
#5 | |
Otherwise you need to manually measure all the pin spacings and go part hunting... reviewing various data sheets of detailed mech drawings for a match. also from data sheet determine the electrical pin locations of the normally open contact match the PCB traces. Fact1) coil voltage is 24Vdc Fact2) the relays normally open contact is going to be across the series of power resistors. It closes that after power is applied.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#6 |
Actually, the relays shouldn't be too hard, that style of relay is quite common. If you post a dimensioned diagram of the relay's pinout from the PCB, I can point out one that will work.
#7 |
I'll measure the board dimensions tonight! Here are pics of the board... (I have to find a ruler somewhere in the house)
#8 |
Second
#9 |
#10 |
Attached is the pitch of the holes for RLY 1&2
| Soft Start Necessary? | dtaylo3 | Class D | 2 | 26th December 2008 09:05 AM |
| Need a soft start? | maxpou | Solid State | 19 | 18th April 2007 09:23 PM |
| Share my Soft Start Module for large Transformers | dddac | Class D | 30 | 3rd September 2005 10:05 AM |
| Soft start & Soft Switch circuit: can anybody help? | m.parigi | Solid State | 95 | 22nd August 2005 03:32 PM |
| Page generated in 0.11883 seconds (73.52% PHP - 26.48% MySQL) with 11 queries |
