Go Back   Home > Forums > Amplifiers > Power Supplies
Old 12th June 2009, 09:43 PM   #1
HaLo6 is offline HaLo6  United States
HaLo6's Avatar
Default Too much capacitance?
I am building a Sigma11 from AMB Labs, C5 is specified as 1 x 2700uF at 63V or 2x1500uF at 63V ... is it a big deal to do two 2200uF at 50V? I am not worried about voltage on the caps because I am configuring it for 5V DC but is the extra capacitance a big deal, I am inclined to say no... but I am not sure of the background EE theory in PS design...
Old 12th June 2009, 10:14 PM   #2
I don't know what a Sigma11 is, but it will probably work. But why do you what to use two 2200uF caps when one will do?
An EE might tell you that in some cases the ESR of the output cap can effect stability. In fact, an ESR of 0 may cause a regulated supply to become unstable.
Old 12th June 2009, 11:29 PM   #3
HaLo6's Avatar
well I didnt know if 2700uF-3000uF was a minimum? I was wondering if 2200uF would be enough too...
Old 13th June 2009, 12:02 AM   #4
infinia is offline infinia  United States
infinia's Avatar
Default Re: Too much capacitance?
It helps to post schematics and any other helpful links so we dont have to assume and/or hunt. Which I didn't bother
3000 to 4400 uF is about an increase of 50% not in excess when considering initial tolerances plus aging of these bulk caps.
I would question such a drastic change in DC voltage from 50- 60V to 5V tho? I think with this kind of change there is whole lot more to consider. Is this a linear or SMPS
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 13th June 2009, 12:17 AM   #5
HaLo6's Avatar
That is the rating on the caps... I am only using a 2x6VAC trafo. Schematic attached sorry.. I should have put up a link...
your signature quote is right up my alley
Old 13th June 2009, 12:22 AM   #6
HaLo6's Avatar
The caps are smoothing caps if that matters...
Old 13th June 2009, 12:26 AM   #7
infinia's Avatar
Yup... a whole lot more to consider.
What's the application?
12Vac>5Vdc not going to be very eff and/or hot
Old 13th June 2009, 02:56 AM   #8
HaLo6's Avatar
That is the smallest toroid I have found and the PSU does have some pretty large heatsinks... Sigma 11
I am going to use it to power the digital section of a TPA Buffalo32 DAC
Old 13th June 2009, 08:37 AM   #9
infinia's Avatar
OK since this is very low power and you have quite a bit of V overhead you should be fine, if D5 and R10 appear on their charts for 5V output.
Old 13th June 2009, 09:26 AM   #10
6Vac might be a bit too low for a regulated output of 5Vdc
Try to find 7Vac to 9Vac for this output voltage.
You can just about use 16Vdc caps for the smoothing at these low voltages.
The worst case voltage from 9Vac is ~ 9 * 1.414 * 1.3 * 1.06 -1 ~=16.5Vpk
regards Andrew T.
Capacitance ak_47_boy Planars & Exotics 11 17th April 2008 08:16 PM
Capacitance in PSU kacernator Tubes / Valves 28 11th April 2008 06:21 AM
PS Capacitance Puffin Chip Amps 8 3rd March 2008 10:17 AM
too much capacitance in PSU??? cbutterworth Power Supplies 0 26th October 2007 03:15 AM
How much capacitance? theAnonymous1 Solid State 4 22nd June 2004 08:01 AM
Page generated in 0.12316 seconds (73.70% PHP - 26.30% MySQL) with 11 queries
