What are the main differences in these two tube power supply? What the best choice for a tube preamp?
#2 |
The first one has an additional stage of filtering.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#3 |
Seriuosly, what the differences to mount two chokes like pic A and two chokes like pic B?
#4 |
The first one has an additional capacitor. At low frequencies, capacitors are much more effective than inductors for power supply filtering.
#5 | |
Depends on the value of the cap and the inductor. The first has indeed an extra stage of filtering. Two stages of filtering means that the final ripple voltage is substantially lower. Also, in the 2nd pic, you pick off your voltage from the terminals of the 2nd cap, and NOT from cap and the secondary tap! That means that your output voltage will be quite a bit lower. Too low, I would guess. Do a sim. Jan Didden
/Another new issue: Linear Audio Volume 3! |
#6 | |
There's a reason why passive PFC (with a large line frequency inductor) has faded away in favor of active PFC (with a small high frequency inductor and control electronics).
#7 |
PSU design not allow to simulate a filter like pic B unfortunately, or I'm not able to do it?
#8 |
If we assume stray capacitances are negligible (which they will be at low frequencies), the circuit will behave the same as if the second inductor was on top in series with the first.
| Differences between X0 and X0.2 | rsbay | Pass Labs | 2 | 27th March 2010 03:40 PM |
| Differences with 6C33 Tube Types | korneluk | Tubes / Valves | 4 | 27th March 2008 05:00 PM |
| subwoofer differences | shawn1972 | Subwoofers | 11 | 5th April 2006 12:53 PM |
| What is the differences between | Richard Moon | Multi-Way | 2 | 23rd September 2002 12:46 PM |
| Page generated in 0.10431 seconds (66.13% PHP - 33.87% MySQL) with 11 queries |
