Tuna can shield
Tuna can shield
Old 20th May 2009, 09:05 PM   #1
DynacoDave is offline DynacoDave  United States
DynacoDave's Avatar
Default Tuna can shield
Any benefit to using a tuna can to shield a toroidal transformer?
Old 20th May 2009, 09:15 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Tuna can shield
Default Re: Tuna can shield
it's certainly prettier ..... especially if you leave original design on it
ok - there is slight shielding effect , too
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 20th May 2009, 09:37 PM   #3
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
I wonder which will shield better, Bumblebee or Chicken of the Sea?
Old 20th May 2009, 11:04 PM   #4
woody is offline woody
I would definitly go for the packed in oil .....
Old 20th May 2009, 11:11 PM   #5
Zen Mod's Avatar
Tuna can shield
boyz ....... don't make fun of serious question
there are benefits certainly , depending of material of which tuna can is made .
Old 21st May 2009, 12:04 AM   #6
Steerpike is offline Steerpike
Steerpike's Avatar
Torroidals have a very 'controlled' flux leakage anyway.
You need to be careful that whatever can is used, it doesn't touch both the chassis and the transformer mounting bolt - as that is efectively a short circuited winding.
Old 21st May 2009, 01:00 AM   #7
All joking aside I seem to rember a discusion of this years ago.
The conclusion was that a thin metal shield like a tuna can won't
be verry effective as a shield. Besides it would hamper air flow
around the transformer and make it run hotter. And as was pointed out you should't have a lot of radiated fields from a toriod.
Old 21st May 2009, 05:10 AM   #8
Conrad Hoffman is offline Conrad Hoffman  United States
Tuna cans are ideal for various things like holding cutting oil at the lathe. If you didn't do a good job of bypassing incoming RF on the mains cable, shielding the transformer might help contain it a bit. Or not. IMHO, toroids are over rated in their ability to magically contain stray magnetic flux. They still induce currents in nearby chassis metal, so they're not perfect, and magnetic shielding requires thicker metal and a full ring- just what you don't want with a toroid. The above mentioned heating is also an issue. I'd probably avoid the tuna can and rely on distance from sensitive circuitry, or go with a mu-metal shield supplied by the toroid manufacturer. OTOH, there's no harm in trying it. Just do some tests for temperature rise.
I may be barking up the wrong tree, but at least I'm barking!
Old 21st May 2009, 06:37 AM   #9
DynacoDave's Avatar
I was , I think, worrying about the short circuited winding. I was under the impression toroidal radiated more than other types of transformers and that was a good reason to put them in an outboard power supply. Are there any good posts on torodals? My searches here have had limited results. Thanks for the info and, the levity .
Old 27th May 2009, 11:44 PM   #10
TechGuy is offline TechGuy  United States
The metal of a typical tuna can has very low permability, which makes a lousy magnetic shield. Tuna cans work well from shielding tuna from the environment, not for magnetic shielding.
http://www.mushield.com/design-guide.shtml
As Eva has discussed in many previous posts, toriod emissions can be controlled by the way they are orientated when mounted on the circuit board.
E-core transformers can use a copper foil band (aka "hum band")installed around the outside of the transformer (parallel to the winding) and attached to ground that creates a current loop to attenuate emissions. However, since the external band is a current loop, it will reduce the efficiency and will decrease the maximum power load of the transformer.
A transformer with low leakage inductance should also help attenuate emissions. This is achived by keeping the close contact between the primary and secondary windings through the entire length of the transformer (ie bifilar, interleaving, etc). Unfortunately most pre-wound tranformers use a split bobbin to maximize isolation, but also maximizes inductance leakage, creating a noisy transformer.
BTW: Avoid eating tuna. Sea food is loaded with heavy metals cause by pollution. The US EPA now recommends limiting consumption of seafood meals to once a month.
Tuna can shieldHide this!Advertise here!
Toroid transformer, shield or not to shield? bays_9a5tt Digital Line Level 10 21st December 2008 03:10 PM
shield or not shield??? Leolabs Chip Amps 13 27th July 2006 09:46 PM
AC shield question AMR Power Supplies 2 31st March 2005 03:37 PM
metal shield dud_wity Tubes / Valves 3 11th July 2004 11:30 AM
Magnetic shield cptnCanada Multi-Way 1 14th December 2001 06:18 AM
