Go Back   Home > Forums > Amplifiers > Power Supplies
Old 17th May 2009, 12:13 AM   #1
Default Silly question
I'm totally ignorant when it comes to voltage, current vac, va etc, etc and there is something I have not found an answer anywhere on the net.
I have a couple of 300VA 230V 2 x 22V toroidal transformers and I have moved to the USA. What happens if I connect them in a 110V mains? Will they not work at all? Will they become 150VA? Or what?
Old 17th May 2009, 04:07 AM   #2
zigzagflux's Avatar
Yes, they will work. You end up with a 150VA transformer, and the secondary voltage will be 2 x 11V.
The transformer will be running at 50% of its designed core flux, and will run quite cool. I wouldn't be too concerned about considering it a 200VA transformer; the core tends to limit capacity more than the winding current, especially in this case where the core will be cool.
Old 17th May 2009, 05:13 AM   #3
Thanks for your answer zig.
I'm glad they will work. However, I will have to use them in another project because I do need at least 18v on the secondaries.
I will have to sell them.
Antonio
Old 17th May 2009, 05:09 PM   #4
Just another question on the same subject.
If I connect the two trafos in parallel will I double the secondaries' output back to 22v??
Basically if the above is true, this way I can still use the trafos but in stead of having one per channel I will have one for both channels.
Old 17th May 2009, 06:07 PM   #5
Mr Evil is offline Mr Evil  United Kingdom
You can connect the primaries in parallel and the secondaries in series to get a single pair of 22V outputs.
https://mrevil.asvachin.eu/
Old 17th May 2009, 07:17 PM   #6
star882 is offline star882  United States
star882's Avatar
Don't forget that you can get 240v in the US by connecting from hot to hot.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 17th May 2009, 08:59 PM   #7
DRNB is offline DRNB  South Africa
Send a message via AIM to DRNB
You will have to connect the two secondary taps in series to get 22V.
Old 19th May 2009, 12:53 AM   #8
Many thanks for your answers. Although I'm doing y homework I will hae to ask more questions since a mistake could be dangerous.
Could you or someone else explain what this means? I live in an apartment and have no access to the electricity board. Just to normal double (wall) sockets.
Also, I do not want to end up doing the wrong thing as explained here: http://www.avahifi.com/root/audio_ba.../ab1993-08.pdf
Is this asuming I do what star882 explained above?
Many thanks
Old 19th May 2009, 01:37 AM   #9
Ah, by the way, this is the way my transformers are wired.
http://www.airlinktransformers.com/t...ansformers.asp
A silly question, but I'm going to ask anyway :-/ TurboFC3S Multi-Way 19 1st April 2009 02:01 AM
Silly Question about 807 7N7 Tubes / Valves 2 17th November 2007 11:14 PM
Yet another silly question! stewartwen Analogue Source 4 17th April 2006 02:19 PM
Silly Question???? Zero Cool Solid State 7 16th October 2004 11:34 AM
A silly question, but... mjarve Solid State 2 3rd August 2004 09:50 PM
Page generated in 0.10207 seconds (77.73% PHP - 22.27% MySQL) with 10 queries
