hi!
i am doing some modifications to an old cd player and want to build a powersupply for the op-amp. the dac i already done this for. but that was somewhat easier. it just needs 5vdc. but as i can see the op uses somewhere between 4,5-24V pos and neg i have tried to build a regulated psu for this but i failed twice. i have ample supply of 78xx and 79xx regulators but i seem to be missing something important, can someone point me in the right direction? is there any good schematics somewhere? the transformer i will use is a 2x15V i have powered the op with 12battery and it worked fine. sounded pretty good. but not very practical cheers |
#2 |
I would probably go with one of the low noise super-regs
such as a Jung, Per-Anders or check these threads The simplistic Salas low voltage shunt regulator Best low noise regulator? |
#3 | |
Yes - the datasheet: |
#4 |
for a +-5Vdc regulated supply you should be using a 6+6Vac to 9+9Vac transformer, not 15+15Vac transformer.
If you pre-regulate down to ~10V and fit big heatsinks you can use your high voltage transformer but that's a lot of extra hardware that can be avoided by buying the correct transformer.
regards Andrew T. |
#5 | |
MJL21193: thank you! is it good for the purpose? |
#6 | |
Absolutely. Here's something more complete: |
#7 |
Or if you want a bipolar shunt reg: http://www.diyaudio.com/forums/showt...12#post1349112
Component values for 39V output and pcb files later in the same thread. Change the zener reference and a couple of resistors for lower voltages. Sheldon |
#8 |
thanks for all the advice.
i managed to get it to work. i used the schematic posted by MJL21193 and some of my own touch. works like a charm. sounds probably as good as a op-amp sounds maybe offtopic but would there be any way to build a SS outputstage instead of the op amp? |
| FS: Hitachi Router and Terk outdoor HD antenna, BD-Rom drive, Xbox HD Drive and more. | Dougie085 | Swap Meet | 0 | 3rd May 2008 07:31 PM |
| Regulated or non-regulated SMPS | longitude | Class D | 5 | 8th May 2007 03:02 PM |
| Idler wheel drive vs. Belt-drive | mig-ru | Analogue Source | 4 | 3rd December 2003 12:06 AM |
| Looking for transformers to build +5V, +12V power supply for CD-ROM drive | Saurav | Parts | 4 | 19th September 2003 02:21 PM |
| Computer Question-Any Problems Transferring Office 97 From D Drive to C Drive | kelticwizard | Everything Else | 12 | 22nd January 2003 03:34 AM |
| Page generated in 0.10098 seconds (75.94% PHP - 24.06% MySQL) with 11 queries |
