The simplistic Salas low voltage shunt regulator
Old 4th August 2009, 06:16 PM   #941
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Only if it has a fan. You are about to burn 2.5A at 12V, I.e. 30W. For the T Amp there is no high constant bias that it burns it so to take the burden off the shunt, like a class A amp with big idle bias and chunky shinks does. It only burns dynamically from it when it plays. The shunt will be getting less heat the stronger the amp plays. When the T Amp idles, the shunt gets it all. You will need a 0.5C per W heatsink.
Old 5th August 2009, 02:11 AM   #942
iko is offline iko  Canada
iko's Avatar
Tham, please let us know how your t-amp works with the new regulator, when you get a chance. Hope to finish my high current version soon too.
Old 5th August 2009, 02:25 AM   #943
Tham is offline Tham  Malaysia
Iko, will try Salas v1 for a start...trying to find the right heatsink now.
Old 5th August 2009, 03:43 AM   #944
iko's Avatar
I think it's a good idea, since we know for sure it works. Good luck.
Old 5th August 2009, 04:32 AM   #945
anatech is offline anatech  Canada
anatech's Avatar
Hi stormsonic,
can you please post shematic for me to understand. One pic is worth more than a 1000 words, hand drawn will be OK.
Sure, no problem. I'm hitting the sack right ow, but I'll scratch out a diagram for you tomorrow.
We may be talking about the same thing, we'll see tomorrow.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 6th August 2009, 12:26 PM   #946
Marinos is offline Marinos  Greece
Marinos's Avatar
Hi all and I wish not to get any answer because you are all at vacations
For some months now, a pair of salas shunts have replaced batteries in my line amp with spectacular results. In order to clean up the mesh and close the chassis I would like your opinion on this.
The line stage consists of a opa627 buffer, a volume control and an opa627 output stage.
Now the shunts go where the batteries before them. That means per chanell per rail
- a small inductor
- 1000 uF
- and then to each chip with 1R/47uF on chip's rail pin
Should I leave it like this or remove inductor + 1000uF ?
Marinos
Old 6th August 2009, 12:40 PM   #947
R.I.P.
Originally posted by Marinos
a pair of salas shunts have replaced batteries in my line amp with spectacular results.........................
- a small inductor
- 1000 uF
if the inductor version sounds spectacular, then why change it?
Only you can experiment and find out whether removing the inductor can make it more or less spectacular.
regards Andrew T.
Old 6th August 2009, 04:15 PM   #948
Salas's Avatar
Its OK as it is, although a coil smooths it up high just a bit, does not alter it, we had experiments, it is still perceptibly positive, if before the shunt. After the shunt it messes with its low output impedance. I don't know if it helps the chips more than what an impedance alteration can do as harm. Bypass and listen, compare.
Old 6th August 2009, 06:40 PM   #949
Marinos's Avatar
Thank you Andrew and salas.
Marinos
Old 7th August 2009, 11:18 AM   #950
Salas, canabalised a heatsink from my unused AV amp and tested my new v1 shiunt for T amp...the output without load measured only about 8V. Is something that I have done wrong?
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
