Go Back   Home > Forums > Amplifiers > Power Supplies
Old 22nd June 2009, 07:56 PM   #631
nicoch58's Avatar
iko
Vout are 44v in all 4shunt ,ok
tomorrow...thanks salas/iko !
Sic58
Old 23rd June 2009, 01:16 AM   #632
Nichoh,
Dig up your old variac - very useful for this.
I've use a dual variable power supply (2 x 30v) for directly feeding the regulators (can easily check current consumption) then connecting to the transformer, diodes, etc with the variac start. Then it's onwards to the rest of the chain, one step at a time.
... jh
Old 23rd June 2009, 12:17 PM   #633
nicoch58's Avatar
first look , two byv27/200 in short ,but are in place ..2A/200v diode!! (caps are small 1000mf and 1000mf on out shunt)
I go to bench for serius test
I have 11dq10
Sic58
Old 23rd June 2009, 03:26 PM   #634
nicoch58's Avatar
trafo ok ,is a bvy27 that lakage under load ,on static is ok , with no load the raw psu burn 700ma fuse on one rail.....
11dq10 (I 1,1A)are ok?? dual bridge x channel
Sic58
Old 23rd June 2009, 03:40 PM   #635
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Yes, but obviously your bridges need sinking. Under the hood and constant current probably gave them a good hassle.
Also watch your reverse voltage to be adequately in spec. Schottky are generally low for that.
Old 23rd June 2009, 03:45 PM   #636
nicoch58's Avatar
ok 4A !
Sic58
Old 23rd June 2009, 04:03 PM   #637
Salas's Avatar
I am talking Vsecondary*2.82 + 50% line transient safety margin, you must have as PIV spec for your diodes. I.e. a 150-200V PIV in your 40V secondary for full bridge. If your new diode is around 100 you will need 2 in series for each one of the bridge =8 pieces per bridge. Or simply another higher PIV part. What was the PIV of your previous model, failed diodes?
Old 23rd June 2009, 04:08 PM   #638
nicoch58's Avatar
yes 4A 600v to220 stuff
byv27 ,2A -200V
Sic58
Old 23rd June 2009, 04:12 PM   #639
Salas's Avatar
11DQ10=problem with PIV
Old 24th June 2009, 10:50 PM   #640
stormsonic's Avatar
how about IRF640?
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
