The simplistic Salas low voltage shunt regulator
Old 20th June 2009, 03:39 PM   #611
c2 will hold the ref voltage down while it starts to charge.
The shunt will try to keep the output voltage down to match the ref voltage and as a result dissipate the full CCS current at the full input voltage until it overheats.
regards Andrew T.
Old 20th June 2009, 04:05 PM   #612
Marinos is offline Marinos  Greece
Marinos's Avatar
Originally posted by massimo
I must come back to Athens not only to visit the new museum then...
P.S. Elgin marbles must come back to Greece!
Today is the opening and you can watch it live from this link Acropolis museum
Scenes I have seen from television sent chills to my body.. The way that the objects has been placed in space gives you a spooky feeling that statues are visitors themselves ... Something that must be seen.
Follow the link and you will understand/feel why the "elgin marbles " are not just marbles and must come back and "fill the holes in their family photo"
Marinos
Old 20th June 2009, 06:52 PM   #613
massimo is offline massimo  Italy
Thank you for the link.
I'm sorry for Andrew who's Scottish as well, but I consider what mr Elgin did two centuries ago a robbery. And only to decorate his private house!
They must be returned to you as Italy did with some parts of famous Greek statues or Axum stelae stolen last century and recently returned to Ethiopia. For once we did it right!
Old 21st June 2009, 01:40 PM   #614
Stuey is offline Stuey  Australia
Hi all,
As some have found, the 2SK170 is not widespread in its availability.
I can get the dual version 2SK389 here, but was thinking of the 2SK246 (GR or BL class). Will this work OK? I just wanted to buy locally if possible.
http://www.toshiba.com/taec/componen...c//53/6917.pdf
Cheers
Stuey
Old 21st June 2009, 02:19 PM   #615
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The one under the Zener must work under BC550's Vbe. Thus its Vgs (off) must be under 0.7V. 2SK246 gives 0.7V as minimal. A solution would be to lift the Vbe to about 2.5V by using a 220R under BC550, emitter to ground. Assuming an Iccs load on its collector of about 8.5mA IDSS.
Old 21st June 2009, 02:37 PM   #616
Salas's Avatar
HV OT.
The shunt Mosfet dissipates less power the less the voltage across it, given the standard CCS current minus what goes to load consumption during start up as C2 charges. In a strong set current scenario, I would be more concerned about the CCS Mosfet which will have to endure more Voltage than final Vin-Vout and full current. The shunt Mosfet pops by oscillation IMO. I would remove C2, see if it does better, and then use a 0.22uF one or 0.33uF to see if it still holds. There is enough Johnson on a 82k we would not want to amplify, left totally unfiltered. Non the less all the working shunts made by now, do have C2 and don't pop. One thing we know is that no working example has been made beyond 100-120mA. Also he must play better safe than sorry and use safety Zeners across Mosfets. I don't use any bcs of no problems, and I avoid their self noise. But Iko suffered problems and must take precautions. Another thing that crosses my mind is what if the Zobel values are not good with the alternative than IRF840 Mosfets Iko uses, and what about any reaction from his amplifier used as load. As for things particular to Iko's test build, as possible culprits or not, naturally we can't know more.
HV OT.
Old 21st June 2009, 03:49 PM   #617
Default oops
Salas, you're right.
During start up, the low voltage across C2 forces the CCS to dissipate more power.
regards Andrew T.
Old 22nd June 2009, 03:04 AM   #618
Thanks Salas.
Old 22nd June 2009, 06:34 AM   #619
Tham is offline Tham  Malaysia
Built one based on Iko's post #456 and hooked up to a Monica 3 DAC for burning in now. It works fine and the noise floor is at least as low as v1 that I built earlier.
Old 22nd June 2009, 07:12 AM   #620
iko is offline iko  Canada
iko's Avatar
That's cool! Any details on the parts used, sound tone change, etc.? BTW, I felt the other day like pushing the limit a bit, and used two mpsa18 instead of mpsa20, and darlingtoned the bd140 with a 2sa564 in front of it. Didn't use any compensation caps, and it was stable on some brutal loads. I measured half the ripple on sine wave load. Just something to keep in mind.
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
