The simplistic Salas low voltage shunt regulator - Page 610 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 23rd June 2013, 07:19 PM   #6091
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
MKP
Old 24th June 2013, 12:41 AM   #6092
Kazuo Ozawa's Avatar
Originally Posted by schultzsch View Post
what other type of caps can be used in the reflektor for C1 and C3? instead of teflons or micas.
I intend to use the regulators to power up a pcm1794 dac
In my experience C1 and C3 have great influence for sound more than expected.
This article would help you
Old 24th June 2013, 06:44 AM   #6093
Thank you guys. I'll give it a read.
I was asking for a substitute type because of the great space that teflons and micas require
Old 24th June 2013, 10:57 AM   #6094
Nice site, in the past i have had read humble... Don't record exactly the name but i'm sure you know of what I'm talking about.
K.. So from what I've read the teflons play neutral and maybe that's what I'm searching for.
For the moment I bought some 50nf russian micas and use them to decouple the pcm1794, the guy on the site you gave the link uses the tested caps in the audio signal path and guess this way you can observe the pro/cons for each cap easier than when you use them as decoupling caps.
Old 24th June 2013, 11:05 AM   #6095
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
This is a good work:
Humble Homemade Hifi
RC
Old 25th June 2013, 11:26 AM   #6096
That is the site I was talking about
Old 26th June 2013, 07:02 PM   #6097
Is the boards still available?
Old 27th June 2013, 07:39 PM   #6098
2A3SET is online now 2A3SET  Canada
How about MA2SP010GL, DA2S00100L or MA2707700L which are available on digikey?
By the way, do you still have bypass cap on ES9018?
Originally Posted by Kazuo Ozawa View Post
On post #5934 Mr. Canvas let me notice that Cxxx of M3 NMOSFET is important factor. I guess lower the Cxxx better the sound. However Cxxx of NOSFET is relatively big. Therefore I decided to look for a higher-performance device for NMOSFET.
Now I have replaced NMOSFET with RF diode. I got MA2S077 which Cd is 0.9pF (typ). Unfortunately it is discontinued. But you can find the substitution easily. Measuring serial resistance (Rs), it shows approx 2 ohm/each on 10mA DC. The Rs tends to become lower over high band frequency.
The sound is more open, transparency and soulful, obtained a big improvement IMO.
I think that Reflektor is affected greatly by two factors at least.
1) The quality of C1
2) The quality of R5
If you use lower quality one you would feel dissatisfaction by all means and could not know the true talent of Reflektor. As long as I used some film caps for C1 and/or winding wire resistor for R5, I was not able to obtain a good result. I recommend that Teflon or Mica for C1 and Vishay VAR for R5.
Next I will study how the quality C3 affects the sound.
best regard
Old 17th July 2013, 05:57 AM   #6099
Sorry, I did not notice your question.
1) It seems MA2SP010GL is better for its lower Terminal capacitance.
2) Yes, I still put on bypass caps on ES9018 board.
I have not yet studied for the bypass caps its necessity, quantity and/or quality. But I can say that even if there is bypass caps, the RefleKtor has a big influence.
Old 26th July 2013, 07:10 PM   #6100
stajo is offline stajo  Sweden
Does anyone know if SSLV BiBs have been used for powering a BoZoS, +/-60 V @ 80 mA? Can it be done, is it recommendable?
Best regards
Staffan
Copyright 1999-2017 diyAudio
