The simplistic Salas low voltage shunt regulator
Old 18th June 2013, 09:38 AM   #6081
samoloko is offline samoloko  Bulgaria
Salas
do you recommend to add to BIB or reflektor a small value resistor to do a RC like The simplistic Salas low voltage shunt regulator
Is It nesassairy that resistor to be a premium part In order not to affect quality of CCS resistor used - Caddock MP serie
Salas hotrodded blue DCB1 build
Old 18th June 2013, 10:10 AM   #6082
Originally Posted by Salas View Post
Don't use 0.1uF local rail decoupling on the load's side when applying the 1.1 BTW.
would you please elaborate on that one
why It Is not recommended to use particular value of 0.1 uF for local decaupling
- Is It recommended to use higher value or ...
I do have 0.1 uF FT-3 and were going to use them as a pre amp power supply decoupling
Old 18th June 2013, 02:09 PM   #6083
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Not 0.1uF only, small super low ESR films in general will interfere with the fixed Zobel termination of the Bib if there is not much inductance in between to really decouple and will cut a lot of phase margin. They have caused oscillation even. We had a couple of practical examples in this thread where they have caused instability that fixed with their removal. Harsher flat sound like when with EMI interference is a clue. Reflektor is more tolerant but its better without too. You can try without any film on the load's rail, short run of 4 wire cabling, or tantalum rail bypass if it has something to really do there. The shunt reg will damp the load's rail differently than a series one, especially on 4 wire connection.
Old 18th June 2013, 02:13 PM   #6084
Salas's Avatar
Originally Posted by samoloko View Post
Salas
Use a 0.33-1R after the bridge to the C filter, it cuts on charge cycle EMI. Roender said he found it good also when with 10000uF he had. MOX type will do. Depending on your Tx, diodes type, and capacitor value it may do good, nothing, or be slightly non preferable.
Old 19th June 2013, 01:52 AM   #6085
canvas is offline canvas  Taiwan
Hi Salas,
How about 1.2R? My 1.2R is used to power the CD transporter which has many 0.1uf ceramics near every VCC pin. I currently put a 47uf OSCON after the power-in connector (as local bypass). Do you think these ceramics will affect the 1.2R?
Old 19th June 2013, 02:02 AM   #6086
Salas's Avatar
Its a complex system to determine. Has RLC elements representing tracks and various decoupling. 1.2R is usually more difficult to disturb because it has a more sophisticated own termination. All those VCC caps add up to bigger also. Try a 47uF Tantalum in OSCON's place and no power-in connector cap at all, to evaluate what of those three works better in the total system.
Old 19th June 2013, 06:07 AM   #6087
Salas
thank you for support
would you confirm that The simplistic Salas low voltage shunt regulator Is last update of 1.2R
can I use sk170 or sk117 In place of 2n5457 which Is obsolete
Old 19th June 2013, 06:35 AM   #6088
Salas's Avatar
You can also use 2SK117GR for Q8,Q9.
Old 19th June 2013, 10:42 AM   #6089
jackinnj is offline jackinnj  United States
jackinnj's Avatar
good lesson for those who make pcb's for group buys -- there is a surface mount version of the 2N5457 and unlike the through-hole version the pad pattern follows most other jfets. so when designing, overlay SMT pads on through hole semi's.
Old 23rd June 2013, 04:53 PM   #6090
schultzsch is offline schultzsch  Europe
what other type of caps can be used in the reflektor for C1 and C3? instead of teflons or micas.
I intend to use the regulators to power up a pcm1794 dac
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
