The simplistic Salas low voltage shunt regulator
Old 12th May 2013, 12:20 PM   #6001
samoloko is offline samoloko  Bulgaria
I am masuring Q3 and Q4 hfe on multimeter - they are 025 - Is that acceptable
Old 12th May 2013, 12:45 PM   #6002
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
I have never got a 4403 under 150 hfe.
Old 12th May 2013, 02:29 PM   #6003
all 4 are 024 - 025 hfe putting on multimeter as In datasheet pin 1 collecor
here what I use http://www.farnell.com/datasheets/1693072.pdf
If I swap transistor and put It on multimeter then I got hfe 345
Old 12th May 2013, 02:42 PM   #6004
Salas's Avatar
What do you mean swap transistor? Turn it, or measure another PNP type like BC560?
Old 12th May 2013, 02:46 PM   #6005
Salas's Avatar
2N4403 is EBC from left to right as we look at its flat face. Use it like that.
Old 12th May 2013, 03:04 PM   #6006
thank you Salas
I used It opposite - c b e - like Is shown on posted datasheet
Old 12th May 2013, 07:00 PM   #6007
pchw is offline pchw  United States
May I ask a question, did you listen to the Shiga before and after the cap trials? I am curious what did that translate into in terms of subjective listening, in this case, of your ears.
I remember seeing a picture that you posted in the Shiga thread some time ago that you had a somewhat long lead to the circuit, and the sense lines were not on the PCB and were half way shorted by a connector. Have you made a change since then? Maybe posting a picture here will also be helpful.
- Fred -
Old 12th May 2013, 09:08 PM   #6008
JimT is online now JimT  Canada
I would like an LTSpice spice circuit for the SSLV 1.1 BIB positive mosfet regulator? I searched but did not find one, but this is a very large thread.
Jim
Old 12th May 2013, 10:42 PM   #6009
Salas's Avatar
Originally Posted by samoloko View Post
thank you Salas
Maybe a datasheet error. Possibly the source of your problems if an error indeed and not a peculiar version of the type which is unlikely.
Old 12th May 2013, 11:01 PM   #6010
Salas's Avatar
Jim
You got to construct it from this picture because as a file has no script models, refers to my hard disk libraries. *The K117s are GR for IDSS. **The open loop analysis setup for which the virtual sources correct positions and plot function I include in the pic is based on Michael Tian's and colleagues paper. You may Google it.
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
