The simplistic Salas low voltage shunt regulator
Old 2nd May 2013, 07:56 AM   #5901
canvas is offline canvas  Taiwan
Hi Salas,
Do you think 4.7uf X7R ceramic is ideal for 1.2R's zobel & vref bypass?
Old 2nd May 2013, 09:42 AM   #5902
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
No.
Old 2nd May 2013, 10:58 AM   #5903
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
Niko I ve been using a BiB for supplying the digital parts of a Shigaclone transport.
Its actual performance is this
Any suggestions to make it behave better? I was thinking something like what we tried for odac
Too many projects... so little time...
Old 2nd May 2013, 11:11 AM   #5904
R.I.P.
Is this 8.2mVac of HF noise on the output of your PSU?
It's not random noise. The pp to rms ratio is too low.
regards Andrew T.
Old 2nd May 2013, 12:53 PM   #5905
Salas's Avatar
That's EMI eat it with a cap.
Old 2nd May 2013, 01:02 PM   #5906
R.I.P.
EMI from the Shigaclone?
In which case the filter needs to be at the Shigaclone.
regards Andrew T.
Old 2nd May 2013, 01:05 PM   #5907
Salas's Avatar
You never know exactly where from if the experimenter won't nail the source. I will show an interesting experiment shortly with a something noise I will try to photograph.
Old 2nd May 2013, 02:04 PM   #5908
Salas's Avatar
1. Bench power supply set at 12V DC. Hooked to scope on AC coupling. ~26mV pk-pk spiky noise. "What a bad PSU!"
2. Same test config. Only that the PSU is powered OFF. ~29mV pk-pk spiky noise. Ooops!
3. Same config (2), opposite view.
4. Capture of config (1).
*MASTECH HY3005D3 bench PSU. RIGOL DS2000 series scope with 20MHZ bandwidth limit ON (signaled by "B" next to the vertical scale indication).
Old 5th May 2013, 07:12 PM   #5909
pchw is online now pchw  United States
In this post, Kasuo San had the 2n4403 thermal coupled. Are the coupling between the mirror pairs?
For my learning purpose, can you shed a little explanation of why the values of resitors and caps in the sobel circuit of the reflecor is very different from the BiB? Also, what is the range of the capacitance in the vref?
Thanks!!
- Fred -
Old 5th May 2013, 08:10 PM   #5910
Salas's Avatar
Its about what has been proposed from the start, i.e. to couple the upper pair. Not he bottom pair.
They are different in analysis, Reflektor is current reaction based, so they get different termination.
2200uF is good so not to be too slow start. But you can add more if its low voltage to reach or you are patient.
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
