The simplistic Salas low voltage shunt regulator - Page 590 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 21st April 2013, 07:09 PM   #5891
I am a little bit curios and intrigued
what difference are between magnetic and non magnetic resistors?
do the non magnetic CMF55-143 woth the purchasing?
Old 22nd April 2013, 03:08 AM   #5892
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
No magnet picks them up. Copper leads mainly or other non magnetic alloys. Subjective buffs say it matters. The CMF are good quality parts in general to have. Good temp coefficient, low ppm, good HF characteristics, self noise is low.
Old 22nd April 2013, 05:17 AM   #5893
the reading I did this last weekend drive me nuts
I think it`s enough with the reading...I have to start building
wanted to change my amp resistors too, actually rn55d with non magnetic cmf ones but after I asked my mentor here on this forum changed my mind ..
now after the things you sayid I think I will stick to normal cmf`s for my ps`s.
thank you guys for you existence and the help you give here on the forum, really apreciated
wish you a very nice week
Old 22nd April 2013, 05:06 PM   #5894
BigE is offline BigE  Canada
BigE's Avatar
What is the rule of thumb for sizing a transformer for a shunt regulated supply?
Is this Expected load requirements + X amps for the regulator?
Old 22nd April 2013, 05:40 PM   #5895
Salas's Avatar
At least 3x the consumed watts spec as asked by the CCS setting at input voltage should keep the Tx cool.
Old 22nd April 2013, 05:41 PM   #5896
BigE's Avatar
Thank you!
Old 1st May 2013, 01:04 PM   #5897
salas do you know any trusted supplier for k170 and k117?
I have just ordered some nice russian 50nf silver mica caps
Old 1st May 2013, 01:20 PM   #5898
Salas's Avatar
Look in ampslab site. Look also in fetaudio site.
Old 1st May 2013, 04:34 PM   #5899
I saw at ampslab that they also have low noise bjt`s Original Small Signal Audio Bipolar Transistors - Buy OnLine @ AmpsLab
which low noise pnp type do you reccomend in place of 2N4403?
I saw Kon`s last schematics for the reflektor and I too would like to try what he did
would like to use a complementary low noise pair from ampslab(if there is one that matches for my requirements) so in this way I will have a spare for future projects too
the k170 he uses is bl and k117 is gr right?
Old 1st May 2013, 06:10 PM   #5900
Salas's Avatar
2N4403 have noise performance in par with 2SA970 keep in mind. That is why I designed around them, a poor man's special and its everywhere to get.
K117 is GR don't use BL anything if not necessary due to stock bcs you will need much IDSS down-regulating resistance that will up its intrinsic noise.
Get a few 2SC2240 & 2SA970 those match well for P-N curves on my tracer. Alas, ampslab has them in BL to GR. So no go. Find some elsewhere. BL if possible.
Copyright 1999-2017 diyAudio
