The simplistic Salas low voltage shunt regulator
Old 27th March 2013, 02:39 PM   #5821
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Its a juggling act since the available gate drive current reduces, so while the OLG goes up lower in freq due to more voltage drive it also starts falling earlier. That ups Zo before 100kHz and it could be associated with your preference for carbon film. All in conjunction with M2 type, Zobel, & specific active load. Also the phase margin changes so checking with oscope is essential as you mentioned. Its a tolerant topology but tweaking that far without visual test gear is not recommended to novice builders I guess.
Old 27th March 2013, 03:03 PM   #5822
pietjers is offline pietjers  Netherlands
pietjers's Avatar
Salas thank you for explaining the effects of increasing R5. I am fully aware of the risks involved, but High End audio is often trail and error, and about pushing the limits. Sonically the circuit reaches a level of performance I have not heard before.
Peter
Old 6th April 2013, 07:41 PM   #5823
samoloko is online now samoloko  Bulgaria
Phew, lots of drawing.
Salas
are these most up to date 1.2R
which one you recommend to power with 24 Vdc Ugs preamp
Old 6th April 2013, 07:58 PM   #5824
Salas's Avatar
Those were the last, yes. Two Reflektors in floating double polarity arrangement would be easier to implement for layout, are anti ground loop, also absolutely the same for semiconductors between the two polarities. Which can be many similar types. The CFP in the 1.2R can be sensitive and give pain in the making and deployment. I will show you a 24V example ASAP.
Old 8th April 2013, 02:31 AM   #5825
Salas's Avatar
Here you are. This can go to 35Vout safely also. Spot on Vo its all about using the proper R8. Or a 10K trimmer. Not best choice for ppm but handy. For finding the right value including current and VF tolerances in a build and then substituting with a good R8 at least. Keep 10V drop over the reg for the 9610 to be on its low capacitive.
Old 8th April 2013, 09:43 AM   #5826
thank you very much Salas
Is this 24 V reflektor a better choice over BIB for powering UGS V3 pre
regards
Old 8th April 2013, 01:20 PM   #5827
Salas's Avatar
They are both adequate. It takes you combine them with a certain preamp and you choose subjectively which one combination you may prefer.
Old 8th April 2013, 01:32 PM   #5828
which one of the BIB, reflektor, 1.2r Is more Independable from wire distance between regulator out and load (25 - 45 cm) and also which one of the three Is more oscilations free than others
Old 8th April 2013, 01:36 PM   #5829
Salas's Avatar
There are general precautions that should be the same but probably the Reflektor would be easier to work with and deploy. It has just one driver block doing it all by monitoring current dif.
Old 8th April 2013, 02:10 PM   #5830
Salas
I see that In reflektor you have lowered zobel cap to 0.1 from 0.47
Is that a tunning mod based on listening tests - Is regulator stable that way
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
