The simplistic Salas low voltage shunt regulator
Old 24th February 2013, 04:38 AM   #5781
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Read SSLV1.1 builders thread. There is much practical discussion around builds and parameters there.
Old 24th February 2013, 09:39 AM   #5782
massimo is online now massimo  Italy
Originally Posted by massimo View Post
...and what about BC547B instead of BC546B (Vceo 45 vs. 65 and Vcbo 50 vs 80) for Q7 when Vout 35V?
Sorry Salas, the quoted post was a question for you. May I use BC547B?
Old 24th February 2013, 11:04 AM   #5783
canvas is offline canvas  Taiwan
Originally Posted by Salas View Post
Also watch what I wrote for R5, R6.
Yes, I am aware of that. Thanks.
Old 24th February 2013, 12:18 PM   #5784
Salas's Avatar
It will be marginal if you will overshoot 35V by 3V when adjusting Vout.
Old 24th February 2013, 12:33 PM   #5785
masterat is offline masterat  Thailand
Thank you very much .
This Link right.
http://www.diyaudio.com/forums/power...tales-213.html
Rice up!
Old 24th February 2013, 01:49 PM   #5786
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Yes.
Old 27th February 2013, 10:17 AM   #5787
schultzsch is offline schultzsch  Europe
There is the 1.1 bib soon on new gb round that you can use in Mosfet for the 5V and I would recommend the low vgs ST output Mosfet p2p version of the Reflektor for lower Volts as discussed some pages before and made in Japan.
with 2 days before you wrote this post the the guy here Salas Reflektor +3.3V with MTP3055VL: Kon??????? wrote the following ''Replacing STP55NF06L with MTP3055VL, I got great improvement. This result suggests that it is better for the Shunt MOS-FET to be less Cxxx''
should this be taken into consideration?
Old 27th February 2013, 12:25 PM   #5788
Salas's Avatar
His goal is having lowest forward on voltage and lowest Crss possible for stretching a Mosfet output Reflektor down to 3.3V use. There are 2 things at odds when there. 1. The available voltage left across the mirror. 2. The bumping capacitance curve of Mosfets at low voltage. Those are the reasons I originally suggested him to get testing with the best logic level Mosfet he can in those respects. Nonetheless, from the moment you have it working above 5V and more so 10V up, the STP or the MTP straighten out for Crss much. The STP is a much higher transconductance device in high current but I did not see the Id/Gfs curve in some datasheet when I looked for the MTP to compare at 1A or below. They could be near at low current. In a nutshell he does well to pursuit the lowest capacitance and on thresholds (VgsTh,Vsd) in his application but for higher Vo it may be increasingly irrelevant. The two types are similar in price and available and you can compare in your own app.
Old 1st March 2013, 07:01 AM   #5789
samoloko is offline samoloko  Bulgaria
where are you buying sk117GR
Old 1st March 2013, 07:32 AM   #5790
Salas,
Can I use STP55NF06L or MTP3055VL over IRF9240 on 1.2R for 3.3v? If yes, is there anything I should take care of?
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
