#5771 |
#5772 |
...and what about BC547B instead of BC546B (Vceo 45 vs. 65 and Vcbo 50 vs 80) for Q7 when Vout 35V?
#5773 |
#5774 |
Thanks dimkasta. Great calculator, now better.
#5775 |
diyAudio Chief Moderator
R5 & R6 break the output voltage referenced across Q3 & Q4 in two. I don't see what is may hinder you for feeding 60Vin beyond the extra heat created across Q1 the larger the Vin to Vout DC difference becomes. The higher the DC across Q1, its parasitic capacitance tames lower. Just know to have Vout/(R5+R6)~3 to 5mA for the LED with resistors that handle the dissipation (Vo/2)*IR5,6 and adequate Q1 sinking with calculated Q1 temp to be still safe. Q5 should sustain the Vout and have capacitance specs similar to what used in the regular schematic. Dropping with RC,RC if the Vi-VoDC is very large is to be also considered.
#5777 | |
Sorry, I should have mentioned earlier. I am going to build a 1.2R regulator for my amplifier VAS stage. My Vin is about 60V, but Vout is around 50V@20ma max. There is only 8V~10V in difference. So, I guess the original schema is fine? |
#5778 |
Q7 will have problems with its dissipation sooner or later at 50V Vo. Better use some TO-126 there with highest beta and lowest Cob you can get.
#5779 |
Also watch what I wrote for R5, R6.
#5780 | |
Have some one guide me how to use?
Rice up! |
