#5741 |
Salas you recomend In older post that Q1 and Q2 got to be tied and matched for hfe
what about Q3 and Q4 - do they need to be tied and matched and also matched to Q1 and Q2 hfe |
#5742 |
diyAudio Chief Moderator
Not that influential than the upper pair. This mirror solves some issues of the just 2 bjt simplest mirror there is. See to have same Vbe in the lower pair and not too big difference in hfe to the matched pair is a thing enough you can do. 5% or even 10% near hfe is acceptable even in the matched.
#5743 |
thank you very much for your patience and generousity
I appreciate very much your support I join boys offered to call you papa Salas |
#5744 |
Papa is only the one and only.
#5745 |
Thou shalt have no other gods before Papa
#5746 |
I want to build the salas shunt to power a class d amp requiring 24 v dc and about 2.5 amp .
Is this feasible with this circuit and if feasible , what are the changes necesary for the schematic in post no 1 of this thread? My transformer is 22V ac and about 300W. thanks for the help k93300 |
#5747 |
Hi, see that post in a relative thread Using the HYPNOTIZE as a general shunt reg PCB
#5748 |
What are the voltage limits for the negative and positive, low current for biasig tubes.
#5749 |
Salas, your shunt is just amazing! After different power supplies tested in my DAC i've powered the single opamp that is after the DAC chip (AK4396) from DCB1 shunt and the sound is amazing, what a voice, what details. I think i will pus some Salas shunt to my every home appliance
![]() If i choose to power also the receiver and dac chips from a Salas shunt and after the shunt i have those Lm1117-3.3 and 1117-5 i still benefit from the shunt advantages ?
Rega RP-1/Simplistic RIAA by Salas/ DCB1 clone/ MyRef Fremen Edition/ XTZ 99.26 MkII speakers Last edited by atupi; 20th February 2013 at 07:24 AM. |
#5750 |
I have been using quite some salas shunts over the past years. I am using 4 LV's and 2 HV's in my dac and even use one to power my 24v Aikido preamp. Very happy with them!
I am not sure whether this topic has been discussed before, but I just read the article regarding regulators in Linear Audio vol 4. To my very surprise, the Salas shunt was evaluated both objectively (rejection, noise, impedance) and subjectively (listening panel) as number 12 out of 13. The comment noted was "slightly coarse, not engaging, competent but uninteresting, not well coordinated, somewhat murky". This does not match my personal findings, although I have not compared with other discrete regs. Does anyone care to comment who DID do HIMSELF a comparison with other discrete (super)regs? Curious to comments! Edit: after reading my post, I want to make absolutely sure that I am very thankful to Salas for this design and as mentioned I am very happy with mine! No harm intended!
-------- TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling |
