#5731 |
Salas
I would like to try Reflektor powering 5V digital at dac would you please advise which Is most actual schematic to use that one from october 2011 http://www.diyaudio.com/forums/attac...kt_squeeze.gif or The simplistic Salas low voltage shunt regulator from october 2012 Which shunt MosFet Is recommended for 5V dc out IRF640 or STP55NF06L what values do you recommend for gate stoppers resistors 220, 150, 100 which type metal film of carbon Last edited by samoloko; 18th February 2013 at 10:54 AM. |
#5732 |
diyAudio Chief Moderator
Do the second one as it is more refined after tests and talk. Use the STP55NF06. Even not the L version when not going under 5V which is much easier to find. Values are on the schematic, use metal film and keep leads towards gates very short.
#5733 |
thank you
Is there a down side to use L version of MosFet for 5 Vdc as I like after that to make a 3.3V regulator just one more question - how can I set V ref to output 5Vdc - setting zener and resistor In series which are parallel to 2 x 820 uF or just resistor |
#5734 |
No down side. Just future proof for 3.3V and more expensive and rare to source. Its a red LED and a trimmer. You just turn the trimmer. For 3.3V its a diode.
#5735 |
thank you
do I need additional 2N4401 transistors like here The simplistic Salas low voltage shunt regulator Is output zobel polypropylene cap the most determinant to sound quality - Is a teflon a good choice Last edited by samoloko; 18th February 2013 at 03:45 PM. |
#5736 |
No, that twist was for really low 1.2V. The bypass lytic(s) and the Zobel cap are indeed influential but not determinant. Choose by your own liking some with balanced price and quality.
#5737 |
why sk117 GR Is preferred to sk170 BL In CCS chain - lesser capacitance ?
Is It so Important |
#5738 |
Surely less capacitance and the current range we opted for. BF245A also. If you got K170GR ~4mA or BL to cut its current down with a resistor you can go by presumably.
#5739 |
I will use K170 BL with resistor
why you choose 4 mA |
#5740 |
To work the specific BJT in a good region.
