The simplistic Salas low voltage shunt regulator
Old 13th February 2013, 10:15 PM   #5711
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
If they will be too close to the load maybe you can trade off. That is why you make them so small so to be really close, right?
Old 14th February 2013, 11:28 AM   #5712
RollE2k is offline RollE2k  Sweden
The reason is actually to fit them inside my case, i have room for two boards in the case that is approx SSLV-size. Unfortunately i need four regulators, which is why i need more compact design. And they will have approx 20cm wiring to the load. Also current will be low, approx 110-120mA total, and the load will draw approx 72-73mA
Old 14th February 2013, 11:53 AM   #5713
massimo is offline massimo  Italy
Roll, would you mind post a bigger pic of your layout? A downloadable pdf will be fine as well.
Tack (thanks)
Old 14th February 2013, 12:09 PM   #5714
Salas's Avatar
Don't feed ebay copiers pls.
Old 14th February 2013, 12:40 PM   #5715
Old 14th February 2013, 12:57 PM   #5716
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Old 14th February 2013, 02:56 PM   #5717
massimo: I could, buy if Salas don't want me to publish it in large format, then i won't.
Salas, do you think it would matter much with the 20cm wires? Since in my circuit it almost would be "good" to have resistance in between, wouldn't this just be pretty much it?
Old 14th February 2013, 03:06 PM   #5718
Yes, I read Salas' concern. No problem, just curiosity.
But if you wish you can send me a PM
Old 14th February 2013, 05:20 PM   #5719
Salas's Avatar
20cm without sense degrades resolution. Its not only the mOhm its the inductance too. Keep them minimal in length and thick if in two wire mode. Twisted pair also for narrow loop area.
Old 14th February 2013, 10:34 PM   #5720
marcus1 is offline marcus1
Default C301, C302... cap question
I'm building a reg with 8V output with mosphet. If my dc input will be around 15V to 18V dc, do I need the caps rated at 50-63v (as per the BiB manual quote below?)
"C102,202,302,104,204,304 4,7uF-10uF/63V MKT radial
C101,201,301 220uF/50-63V. C103,203,303 47uF/50-63V.
C105,205 4700uF/63V pitch 10mm snap-in up to 200mA. 10000uF/63V 10mm snap-in ''hot-rod''
Will caps rated at 25V be OK in my case?
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
