The simplistic Salas low voltage shunt regulator
Old 6th February 2013, 11:05 AM   #5691
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
No, its Oliver's PCB V1 they used for an AD filter-less dac with SRPP I/V.
Old 6th February 2013, 01:07 PM   #5692
samoloko is offline samoloko  Bulgaria
It Is Hypno shunt clone
Old 6th February 2013, 03:20 PM   #5693
pedefede is offline pedefede  Denmark
Originally Posted by Salas View Post
Still needing 100mA+ extra current to work nicely, due to the VMOS used. SMD other parts may cut you enough PCB area but your non shrinking problem will still be the sinks. So not a really drastic change to go SMD.
If you mount the FETs to chassis, and have electrolyts for C (for clocks), you can make the pcb real small
Old 6th February 2013, 03:54 PM   #5694
noSmoking is offline noSmoking  United States
noSmoking's Avatar
HI,
Thanks for the complements and the advise,Yes a little ripple way up but very acceptable ,I will see if it can be eliminated,I didn't need the relays so Thats why I constructed the Mez,It works good ,I have nelsons B1's also and compared them,In my ear at the same volume level they are the same,Both Excelent,The shunt is prettier all those lights,Might go in a Clear top case,lol.
Is the circuitry for the newer designs better? Sound better?,lol.Maybe I should build one and see,
I see those boards are in the store ,might have to get one,,,,,,,,
Thanks Alot,
NS
Old 6th February 2013, 05:04 PM   #5695
Salas's Avatar
Most reports claim they can distinguish the DCB1 from B1, only the lack of 2 coupling caps should be a change. The Mez board on the store gives you full switching capabilities but has no core audio circuit differences to what you put together.
Old 6th February 2013, 05:36 PM   #5696
schultzsch is offline schultzsch  Europe
hello Salas ,
I want to build a final version of my dual mono pcm1794 dac and I was wondering which version of all do you reccomend for 3.3V and 5V?
now I use V1 and 3 x 53Ah LiPo cells to power the little pcm`s.should I change to one of the newer versions?
thanks
Old 6th February 2013, 05:39 PM   #5697
Salas's Avatar
There is the 1.1 bib soon on new gb round that you can use in Mosfet for the 5V and I would recommend the low vgs ST output Mosfet p2p version of the Reflektor for lower Volts as discussed some pages before and made in Japan.
Old 6th February 2013, 05:51 PM   #5698
from what bib comes?
in my 3.3V shunt I use bd140 if I remember correctly
didn`t manage to find that discussion
Old 6th February 2013, 06:24 PM   #5699
noSmoking's Avatar
AAHH Good ,
Thanks for that info on the B1-DCB-1,circuits are very similar,
I fiddled with the scope probe and it did indeed move the wave form ,so it is correct that my measurement is not totally accurate,my meter also influences the signal,It sounds good and I am HAPPY with it performance , Thanks again,SALAS.
Happy Listening!
NS
Old 6th February 2013, 06:43 PM   #5700
Salas's Avatar
BIB means back in black for returning to black solder mask-gold pads boards GBs color scheme. Its the SSLV1.1
As for the 3.3V Reflektor you could not find, here it is The simplistic Salas low voltage shunt regulator & The simplistic Salas low voltage shunt regulator
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
