Go Back   Home > Forums > Amplifiers > Power Supplies
Old 4th February 2013, 02:45 AM   #5681
KMossman's Avatar
Send a message via Yahoo to KMossman Send a message via Skype™ to KMossman
Originally Posted by AndrewT View Post
if you need a Vref between 1.3V and 2.2V.
Two LEDs in series can work out better.
mmmmmmmmmmmmm usually the Vd for a [visible light] LED ranges from 1.6v [if I recall properly] or so to 3V or more................depends on color and type of LED
Old 4th February 2013, 02:51 AM   #5682
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Most generic reds give me 1.8 to 1.92V these days, greens 2.1 to 2.2V, have older red and yellow ones in the 1.65-1.75V. Talking 2.5-5mA bias.
Old 4th February 2013, 02:55 AM   #5683
Salas's Avatar
Originally Posted by ikoflexer View Post
Measuring with the scope probe this way will always add some noise, in my experience. For critical measurements I always take the probe sheath off and use a very short solid copper wire from the scope probe to the load ground. Makes a big difference for sub-millivolt measurements. Hehe, your work brings back good memories.
Indeed. Those springy short path to earth bits come free in the bags of even $20 ebay "100MHz" at x10 probes and we better always save them somewhere, they come handy.
Old 4th February 2013, 09:41 PM   #5684
johnm is offline johnm  United Kingdom
johnm's Avatar
Originally Posted by johnm View Post
After using the above shunt PCB with a DAC for quite some time for 5v output into a DAC, I have decided to re-use this shunt PSU for my Creek OBH-15 phono stage (24v 30mA required) as I no longer use that particular DAC.
A 5K trimmer, and 15R 5W current setting resistor will be substituted onto the shunt PCB, to enable setting 24v.
Whilst the Creek isn't the Highest of Fi, it's still pretty good, and will do until I finally get together all the parts for a Salas RIAA stage.
Until then, I'm seeing what effect using the above shunt reg will have on the Creek phono stage.
Just one question, I seem to remember reading somewhere in this thread (and I cannot find it after a search!) that for a transformer roughly AC volts in = DC volts out. So if I require to use this shunt for 24V output I assume I need to purchase a 2x12v transformer and wire it for 0-24v?
Have I got that right?
Many thanks
- John
P.S. Will I need heavier duty heatsinking than shown in the above picture to run this shunt reg PCB at 24v instead of the original 5V? Ta.
Old 4th February 2013, 09:53 PM   #5685
Salas's Avatar
Yes to both questions.
Old 4th February 2013, 10:01 PM   #5686
KMossman's Avatar
thx. if I might add that the ultra-bright white LEDs can exceed 3V
Old 4th February 2013, 10:01 PM   #5687
johnm's Avatar
Thanks Salas
John
Old 4th February 2013, 10:06 PM   #5688
canvas is offline canvas  Taiwan
If I remember correctly, there is noise consideration. White (blue) LEDs are noisier than red, green ones.
Old 4th February 2013, 10:07 PM   #5689
Salas's Avatar
But not that usable in our referencing purposes here because noisy enough. Sure low noise and lowest Vf are IR LEDS.
Old 6th February 2013, 10:57 AM   #5690
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Many thanks
- John
Hi John
Is this a BiB clone ?
RC
Copyright ©1999-2013 diyAudio
