Go Back   Home > Forums > Amplifiers > Power Supplies
Old 11th January 2013, 11:46 AM   #5661
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
P.S. Why such a big cap? Needing absolutely minimal 1/F noise between 0-10Hz for digital clock and such?
Old 11th January 2013, 11:48 AM   #5662
roender is offline roender  Romania
roender's Avatar
Originally Posted by Salas View Post
Not really with such a big cap swamping it, if you mean connected like in the attached clip.
Exactly!
Thanks.
I have to confess that a very big reference capacitor, especially one with very low ESR, is a plus for regulator audio signature.
I used with success on that position 2200uF Panasonic FC. The regulator is used for a preamplifier with very poor power supply rejection.
Old 11th January 2013, 11:54 AM   #5663
Salas's Avatar
Such an enormous cap brings down the ref impedance a lot but it would certainly kick back hard, no doubt protection is a must. How did you manage a good layout with such a monster? Put underneath?
Old 11th January 2013, 11:57 AM   #5664
Salas's Avatar
Ah, sorry, not 22000, 2200. I read it too fast. Should be no more than 22mm D if 25V.
Old 11th January 2013, 11:59 AM   #5665
roender's Avatar
Thanks to a very permissive PCB design, it fits without any problem on the BiB board :-)
Old 16th January 2013, 05:27 AM   #5666
Guys, i have searched the thread but did not find an answer.
I am at the optimization stage of my dac and thinking of tackling power supply impedance to the tda1541 and clock. Unfortuntely i am not in a position to measure output impedance in circuit (no money for a network analyzer).
So second best is simulations....I have seen the output impedance models posted over the years. However has anyone ever posted some info on optimizing the output impedance of the reg in conjunction with one or more decoupling caps? In digital we are looking at as low as possible into the >10mhz range..... Are there any tried recipes out there?
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 16th January 2013, 06:15 AM   #5667
Salas's Avatar
Track inductance, shielding, local decoupling, and layout are the catches at such frequencies, only RF engineering will answer there.
Old 16th January 2013, 07:04 AM   #5668
gootee is offline gootee  United States
You need to have an array of many caps, on a two-sided PCB with unbroken planes of copper on both sides (drill holes only, with denuded hole edges on one side of pcb, for cap leads). You'll have one of those as each power rail. They need to be shaped right, not long and narrow.
With a 10x10 array of 1000 uF electrolytics, and a 1mm thick FR4 board, you should be able to get the total inductance seen at the load down to less than 1 nH; probably to 0.5 nH.
You might want to use a daughterboard for your main circuit, with standoffs so it is straddling over the edge(s) of the cap array board(s) (depending on whether you need dual-polarity supply), so that all of the power and ground pins can go straight down through the duaghterboard and directly into the cap array board(s). [Or, of course, use a real multi-layer board, with caps distributed all over the board, and power and ground feeds distributed all around their layers.]
The illustrious Terry Given, electromagneticist extraordinaire, presented a prototype, with actual network analyzer measurements, and design guidelines, right here on diyaudio (His was for power amps. Maybe you can re-size caps as needed.).
I created a set of links directly to his posts about it, so people wouldn't have to search for them individually, and wouldn't miss any, which I put at the bottom of the post at:
LM3886 component selection
NOTE that in the first link, Terry meant to say RADIAL instead of AXIAL.
P.S. Also do a google search for papers and webpages by Henry W, Ott, Bruce Archambeault, Eric Bogatin, and others.
P.P.S. There are much-cheaper but more-labor-intensive ways to measure impedance, than a network analyzer.
Enjoy,
Tom
Old 16th January 2013, 03:26 PM   #5669
Triodethom's Avatar
Hi Salas I have a st-1700a distortion meter. It has a 15volt plus/minus supply for each of the section osc. and detector . the raw voltage before the regs is about 35 volts+/- each rail . If I use your regs should I pre reg the voltage down to what ? Thanks for your view .
Old 16th January 2013, 04:49 PM   #5670
Salas's Avatar
Just use CRC down to 25V DC. If its not constant draw, avoid 317,337, better use Zeners.
Copyright ©1999-2013 diyAudio
