The simplistic Salas low voltage shunt regulator
Old 13th November 2012, 08:05 PM   #5561
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
35 το 40ish will be good. You don't wanna go far up to save dissipation on the CCS. It will be running 250mA times the voltage across the reg.
Old 13th November 2012, 08:21 PM   #5562
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Old 13th November 2012, 08:45 PM   #5563
Salas's Avatar
How much current your application asks for?
Old 13th November 2012, 09:21 PM   #5564
hmm, not sure
maybe 2x 3 gain stages of j310 (simple boz variant)
or just 3 stages
I have trafo with dual secondary, could make one reg for each channel
I think each jfet runs at about 5ma or so, not much
what is that ? 1watt ?
Old 15th November 2012, 11:48 AM   #5565
spartan is offline spartan
Default shunt reg for simplistic riaa
Salas,
For the regulator on the attached pdf, aren;t the values for the VDC and VAC mixed up? It's not clear to me what you mean by "The input voltage of the shunt is 38 or 48 V DC, so a 28 or 36 V AC transformer is needed".
Can you please clarify what should be the input DC voltage to the regulator if I'm using the 28V (MM) operating circuit? Is it 36, 38, or 48V? Can you also confirm where I should go in with that voltage in the regulator?
I don't know what "force wire" and "sense" refer to either..
Old 15th November 2012, 11:59 AM   #5566
Salas's Avatar
28VAC x1.35=38VDC. Don't expect x1.414 with real components. 10V drop over the regulator is a recommended number for it to work fine including some mains tolerance even.
Nothing looks mixed up.
Old 15th November 2012, 12:04 PM   #5567
Salas's Avatar
Sense and force are 4 wire Kelvin connections.
Old 15th November 2012, 12:38 PM   #5568
I guess I was confused by the operating voltage of the phono stage (28 or 38) and the transformers needed for the reg. Sorry about that and thanks again.
Old 19th November 2012, 04:55 AM   #5569
didiet78 is offline didiet78  Indonesia
Originally Posted by Salas View Post
I have got double layer with on board rectification and filtering. Maybe you can follow some ideas from it though. If you will have your raw DC part on a different board add a decoupling capacitor across the reg's board input.
New reflektor Circuit using bipolar or Just use Bipolar Library for Mosfet? If later, it got wrong pinout. Drain M1 connect to Drain M2.
Didiet
Old 23rd November 2012, 03:17 PM   #5570
alibear is offline alibear  United Kingdom
alibear's Avatar
Hi all, is there a formula to calculate the heat sink size to accomodate both IRFP9240 transistors when using a version 1 circuit.
Thanks for your help
Alan
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
