The simplistic Salas low voltage shunt regulator
Old 9th November 2012, 10:56 AM   #5551
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by dahlberg View Post
I wonder if it's possible to use the salas regulator as a filament dc supply.
What's available is 7.5v ac and that is supposed to end up as
4,75-5,25v dc @1,8A.
Is this possible and how much ac ripple is there to be expected at the output ?
It has been done for heaters using a basic V1 special with low Vbe power BJT output by member disco for a #26 preamp down to 1.5V.
You would need a heavy PMOSFET in the CCS basically, and the lower impedance MOSFET output versions are still OK for your circa 5V. Don't ask for sure ripple numbers, we haven't used a config as you describe before. You may try a Reflektor with IRF9640 at CCS and STP55NF06L at output. ICCS=Vbe/R1. Set 2A+. Watch CCS MOSFET's dissipation, it will be around 10W.
Old 9th November 2012, 11:01 AM   #5552
Salas's Avatar
Originally Posted by samoloko View Post
what Is and what for reflector Is used
Its a regulator mixing shunt current sinking and current mirror control principles. Its used for powering various circuits with rather nice subjective results.
Old 12th November 2012, 08:42 PM   #5553
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
hi, if I want to build the +30V shunt reg on proto matrix board, and not the most complicated one, which version would you recommend ?
Old 12th November 2012, 08:55 PM   #5554
Salas's Avatar
Reflektor
Old 12th November 2012, 09:09 PM   #5555
Salas's Avatar
... Here is your asked example. Good luck.
Old 12th November 2012, 09:10 PM   #5556
I was searching hard thanks
Old 12th November 2012, 09:13 PM   #5557
Salas's Avatar
You would not find it exactly, I just set it for you. Use 1W R1. M2 is an easy to get Fairchild, but you can use ST Micro STP55NF06 too. Analogous.
Old 12th November 2012, 09:17 PM   #5558
Salas's Avatar
P.S. you can trim R6 with adding some little more value to it for 30V sharp if it ends up less than target, depends on your semis bias. Better than a trimmer.
Old 12th November 2012, 10:07 PM   #5559
thanks chief
what a monster, driving a wimpy SMD j310
Old 13th November 2012, 07:08 PM   #5560
schematic says +40Vdc input, which is fine
but is there any 'slack' on that, plus minus a few volt maybe, or any specific limits ?
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
