Go Back   Home > Forums > Amplifiers > Power Supplies
Old 7th November 2012, 12:54 PM   #5541
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by alibear View Post
Thanks for the replies. Attached is the circuit I will be using.Sorry I am so dumb, but i still do not understand how to calculate the value of R1.
Alan.
This one will blow Q2 if with 50V+ Vin. Exchange Q2 & R3 for a 10K 1W. R1 sets the current by Ohm's law when dividing the difference of voltage across 3 Leds and Mosfet's Vgs (voltage across gate and source pins). Its like in DCB1, 10 Ohm should give between 160 and 200mA depending on Leds and MOSFET. Start with 6.8R 2W resistor and red generic LEDS for 250mA you mentioned. The voltage drop across the resistor divided by 6.8 will give you the exact current in your build.
Old 7th November 2012, 04:03 PM   #5542
alibear is offline alibear  United Kingdom
Thank you Salas, I now understand how to calculate R1. Is there any other FET that I could use in place of the Q2 2SK170, as I think I have read in one of your posts that using a transistor in that position made an audable improvement over using a resistor. I will of course follow whatever you recomend.
Many thanks
Alan
Old 7th November 2012, 05:05 PM   #5543
Salas's Avatar
You may use a ring of two CCS at 5mA with 60V transistors at the LEDs tail, I have shown such examples before. The 10K is the simplest substitution because K170 is 40V only.
Old 8th November 2012, 04:46 AM   #5544
Kazuo Ozawa's Avatar
Default Reflektor +1.2V
I have been evaluated in a few days, and decided to optimize Zobel.
Old; 0R47+0.44uF New; 0R2+2.2uF
As a result the sound became more smooth, transparent without stress. Space is fully filled with music. Of course it is stable strongly. I am satisfied.
Now I noticed on one principle foolishly.
In the Bode chart, if Zobel is optimized rightly, the gain and phase of output are changing smoothly beyond audio frequency zone.
Salas, is it correct?
Old 8th November 2012, 06:11 AM   #5545
Salas's Avatar
Yes its true. Still it has to do with possible load oddities too. So there is safer general termination or optimized. You could end up to something bit different in another DAC for instance. Checking stability with your scope is the first testing principle when making changes as you have mentioned.
Old 8th November 2012, 11:05 AM   #5546
Thanks Salas.
Old 8th November 2012, 11:54 AM   #5547
Thank you for your assistance Salas, much appreciated
Old 8th November 2012, 12:07 PM   #5548
RCruz is offline RCruz  Switzerland
RCruz's Avatar
In my experiments with the reflekor I also found 2uF better than 0.47u in the output zobel.... Of course I was powering a simplistic and not a DAC so results are system dependent.
RC
Old 8th November 2012, 12:50 PM   #5549
what Is and what for reflector Is used
Old 8th November 2012, 03:22 PM   #5550
I wonder if it's possible to use the salas regulator as a filament dc supply.
What's available is 7.5v ac and that is supposed to end up as
4,75-5,25v dc @1,8A.
Is this possible and how much ac ripple is there to be expected at the output ?
Copyright ©1999-2013 diyAudio
