Go Back   Home > Forums > Amplifiers > Power Supplies
Old 3rd October 2012, 05:56 PM   #5441
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by johnm View Post
I used 4700uF Nichicon KG with Qspeed diodes, and on the shunt PCB 220uF Elna Cerafines. Been very impressed with the latest black-skinned versions of the caps. Guessing they've been subtly improved over the years. Actually prefer these to Black Gate standards now. Looks like I got lucky with the component synergy - really powerful, but natural reproduction. Hugely involving. Dare I say it, the DAC is sounding pretty damn close to well mastered vinyl now
You can't run an Aston Martin on dirty petrol, can you? Its the same with PSU juice. Must be clean. When shunt is high octane also.
Old 4th October 2012, 08:04 AM   #5442
Salas's Avatar
Originally Posted by Dr.H View Post
Can you recommend MOSFETS and transistors for a 100Vin, 75Vout?
Then also for a 75Vin 38Vout?
Can we use 2sk170 in these as well?
This config should do theoretically. For 75Vin & 38Vout R9 should be 24K, R6 8.8K, C2 50V. For 75Vout R6 can't be a trimmer reliably, for 38V a 0.5W trimmer will not suffer initially but better not for long term. FAIRCHILD KSA1381/KSC3503 can be found in large stockists, prefer ESTU hfe grade. Its power inefficient to use shunt regs with such constant current over load demand allowances in those voltages, watch your thermal planning and M1,M2 sinking.
Old 4th October 2012, 05:17 PM   #5443
Only BJT output version there is for V1 and 1.1, the CCS is still Mosfet. I recommend full Mosfet if looking for 5V and up. 1.1 guide you can find in "SSLV 1.1 builds and fairy tales" thread, post#1
Thanks Salas :-) I'll take a look at it ....
Jesper
... Being mindful about sustainability also in my audio endeavors matters to me ... paying CO2 - and a quite fair pollution - compensation helps create a good listening "energy" ...
Old 5th October 2012, 08:03 AM   #5444
Thanks Salas, at the moment there is Zener being used for both. Sure this will be much much better!
Old 5th October 2012, 08:13 AM   #5445
Salas's Avatar
And much much hotter. What is it for exactly, do you know the load's max demand in mA? This knowledge can save you heat for knowing your CCS setting limits leading to better setting decision.
Old 5th October 2012, 11:22 AM   #5446
johnm is offline johnm  United Kingdom
johnm's Avatar
Absolutely! It's a turbo-charged beast from hell now
Thanks for getting me yet another step closer to the music
J
Old 8th October 2012, 10:42 AM   #5447
Phisci is offline Phisci  South Africa
Salas, newbie here. To measure the peak current used, can I insert a 1R resistor between the last smoothing cap and circuit being fed (say DAC) and measure voltage across that? Would that not be an average DC voltage? How would I estimate peak voltage (and hence peak I from V/1R)?
Old 8th October 2012, 12:08 PM   #5448
Salas's Avatar
Do that with 1R to know, play full signal, the most DC drop you can achieve with 0dB digital peak program.
Old 8th October 2012, 01:29 PM   #5449
Cheers, will try that.
Old 9th October 2012, 02:14 PM   #5450
More questions if I may: Can I run several loads off 1 shunt reg (for example 74hc74 flip flop as well as a DAC (+5V))?
What about using one transformer with multiple secondaries to power several of the shunt regs?
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
