Go Back   Home > Forums > Amplifiers > Power Supplies
Old 26th September 2012, 03:47 AM   #5331
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Lets hope it will open the Mosfet gate less capacitive at least.
Old 26th September 2012, 01:10 PM   #5332
So I am building REFLEKTOR (probably 5V and 10V) tonight. Any things to watch out for (layout, oscillations, etc)?
Old 26th September 2012, 05:57 PM   #5333
Salas's Avatar
If you got wire leads between rectification/main filtering to reg's input decouple the reg's input with 0.1u to 1u to ground. Tie the top shelf mirror BJTs face to face. Make it tight especially around the input CCS. Scope it for stability. Good luck.
Old 27th September 2012, 12:52 AM   #5334
Kazuo Ozawa's Avatar
Originally Posted by Kazuo Ozawa View Post
Of course, I have observed that it does not oscillate.
I have to correct the previous report.
The attached photo shows that my regulator is oscillating.(Vertical X10) First I thought that it was normal fluctuations.
Salas. I was searching low Cxxx MOS FET. The device you propose is the best as far as I found out. Now I am purchasing STP55NF06L. I will report later.
Old 27th September 2012, 01:03 AM   #5335
Salas's Avatar
~50ns period, that is very high. 20MHZ. Also low in amplitude. Can it relate to any clock fundamental or harmonic since you use them for digital? Anyway put 0.1R at the +side on the DAC's particular power feed point and see if that waveform damps away.
Old 27th September 2012, 02:01 AM   #5336
Your response is always quick.
I thought as same what you guess. But when I moved the board by chance, the waveform became quiet like a ground noise. So I found it oscillates.
In other words, I say Salas Reflektor is excellent regulator if it runs stably.
Old 27th September 2012, 02:09 AM   #5337
Salas's Avatar
This is very high a frequency, if it is just a matter of moving it maybe you need shielded coax and/or to shorten/redress the wires loop. Or to dampen it as I mentioned. Maybe your new Mosfet with less capacitance will make it less sensitive, but it may very well be it just picks something over the wires so try to address that as it is made now. I see much loose wiring in #5326 as it is in test configuration now. In any account make sure that when the whole configuration is assembled as a final system the layout is economical for wire loops and there are no waveforms.
Old 27th September 2012, 05:27 AM   #5338
Hi Salas, built Kazuo Ozawa version (5V) of your reg. A few observations:
1. I am using the reg to power a shunt LDR on my balanced pre-amp. I was not expecting much, given that it's just a shunt. The shunt reg is being fed by a "ALW super reg" which takes raw dc (18V) and down regulates it to 10V. Your shunt reg is then fed the 10V to produce 5V output.
2. I was surprised by the mid-range, which seemed more present/live/real using this reg in this position. I listened till 130am this morning and only went to sleep because I had to be up at 530....
3. Very keen to try the reg with the transport, DAC but....
4. I noticed at start-up that the shunts voltage output would initially spike to around 5.8-5.9V before quickly settling at 5.00V. Is this normal? I do not believe my DAC's can live above 5.5V....
5. Second q: What is the reg doing that makes it sound so good? Is it filtering noise in a way that other regs cannot?
6. Thanks for the circuit, great performer!
Old 27th September 2012, 06:08 AM   #5339
roender is offline roender  Romania
roender's Avatar
Hi guys,
I strongly recommend to all SALAS shunt regulator builders to insert a small value resistor between positive output of bridge rectifier and smoothing capacitor. This resistor should drop around 1V and it's value will depend of the designed current value of regulator.
Old 27th September 2012, 06:30 AM   #5340
Hi Dr.H, congrats.
It is curiously, in my case output voltage becomes up slowly and few minutes later becomes down slowly almost from 5.1V to 5.0V.
Copyright ©1999-2013 diyAudio
