#5311 |
This is a link to a 3.3V REFLEKTOR:
Salas Reflektor 2011 +3.3V???????: Kon??????? |
#5312 |
diyAudio Chief Moderator
Looks like it. The Renesas low Vgs & high Yfs semi tells the lower threshold tale. Should had been easier to oscillate and to had needed the much different Zobel values due to high Crss.
#5313 |
P.S. Kazuo-san may post to discuss it & clear the assumptions?
#5314 |
Salas, for beginners like myself is there a place where I can read the thinking behind the shunt supplies and REFLEKTOR?
#5315 |
Post #4287 in this thread explains the Reflektor and has some history of its older roots.
#5316 |
#5317 |
Kazuo-san used that Mosfet type to go 3.3V he certainly tested those values in his schema. If he will post he will explain further I suppose but he already mentioned that a quad of those regs are @ work in his latest Sabre DAC build.
#5318 | |
http://waltjung.org/PDFs/Dont_Shun_t..._Regulator.pdf |
#5319 |
The Sabre DAC seems to be working well for me. But I have only poor oscilloscope. It is possible that I can not observe osc.
When I move the position of the reg. board, it may sometimes oscillate obviously. Honestly saying, I have no confidence the value of Zobel. I would like to wait for diyer's suggestions. Attaching is the latest version. |
#5320 |
Sorry, this is the latest schematic.
And now I don not use four wires(F&S). Next step I will try. |
