The simplistic Salas low voltage shunt regulator
Old 10th September 2012, 01:44 PM   #5301
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally Posted by jambul View Post
since it can not applied below 7v
Hi Denis
Why do you say so ?
RC
Old 10th September 2012, 02:04 PM   #5302
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Its the Vgs barrier of the output Mosfet and the Vbe additions of the mirror transistors. When running a high power Mosfet at 200-300mA its Vgs is sleeping enough and it can get you near 5V when compromising the mirror for voltage, that is why I recommended 7V floor, to have room. With low Vgs TTL Mosfets things change for margins.
Old 10th September 2012, 05:15 PM   #5303
Dr.H is offline Dr.H
Hi Salas, asking the same question Phisci asked. I'd like to use the REFLEKTOR for my pcm63 dacs. How would I get the voltage to 5V? Or is it just a matter of building the Japanese version? Or could one actually use a reg after like 7805?
Old 10th September 2012, 05:38 PM   #5304
Salas's Avatar
As I wrote above it will work. Just use a 500R trimmer. The 5V Kazuo San build worked with the same IRF640 Mosfet as noted on his schematic along his preferred parts and values mods. Its not another version.
Old 10th September 2012, 05:41 PM   #5305
Salas's Avatar
P.S. Using a chip reg after output is nullifying the effort, no real point. It could enhance as a pre reg but its small change.
Old 10th September 2012, 06:03 PM   #5306
Many thanks
Old 10th September 2012, 07:35 PM   #5307
nhinstruments
RCruz's Avatar
Ok.. it needs a 7 V floor... I use 10v floor... but it can work outputting 5v, you just need to input 5 + 7 = 12v to have enough headroom right ?
RC
Old 10th September 2012, 07:55 PM   #5308
disfunctionalshadow is offline disfunctionalshadow  United States
I wonder why Kazuo-san chose the LE 820uF? Was it simply the value of the summed capacitance or that the 100KHz ESR is 5mOhms, thus 2.5mOhms in parallel?
Old 10th September 2012, 08:12 PM   #5309
Salas's Avatar
No, 7Vout as a whole is enough for hot rod even *spared current pushes Vgs up.
Old 10th September 2012, 08:31 PM   #5310
Salas's Avatar
P.S.
Vin-Vo is another story than VoMin, follow the normal practice with such regs. No less than 5V Vin-Vo not to goof up the CCS, 10V projecting for good measure against Tx & mains tolerance. Although you may find that this class of regs can regulate very near to Vin=Vo (one Vbe dif) the CCS will lose steam.
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
