Go Back   Home > Forums > Amplifiers > Power Supplies
Old 16th June 2009, 08:54 PM   #521
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Sensing returns are used (syn08 and others) with success. Its valid. Can you show it graphically for those in need of long leads?
Old 16th June 2009, 09:17 PM   #522
ikoflexer's Avatar
Have they (others and syn08) discussed the changes when sense is routed this way?
BTW, I made a mistake above, saying that 20cm of cable would be 2mOhms, when it is actually 4mOhms.
Here is the output impedance of v1 as I always simulate it, without a resistance between OUT and Load.
A resistance of 5 milliohms, sense components connected as usually shown in the schematic.
And sense components connected directly to the load.
I think people in general may not realize what a big difference this can make. I didn't until I actually simulated it.
Old 16th June 2009, 09:30 PM   #523
Salas's Avatar
OK with the difference graphs, but I actually meant schematically of how to practically connect.
Old 16th June 2009, 09:56 PM   #524
ikoflexer's Avatar
Somebody with more graphical talent please fix this.
Old 16th June 2009, 10:12 PM   #525
Salas's Avatar
Is this OK?
Old 16th June 2009, 10:31 PM   #526
ikoflexer's Avatar
Not really: source of Q4 does not connect directly to drain of jfet J3 but it connects directly only to drain of Q1 and OUT; otherwise it is ok. I have to run now, but I'll come back later and try a proper drawing, sorry about the misunderstanding.
Old 16th June 2009, 10:51 PM   #527
Salas's Avatar
Better?
Old 16th June 2009, 11:13 PM   #528
ikoflexer's Avatar
Perfect! Thanks. The simulation shows that output impedance is almost not affected at all even by quite a resistance between OUT and LOAD, where as before even 200uOhms would have an effect.
In theory I knew that sense and main current paths should be separate, but didn't think that it would make such a difference in this case. I will test it in practice and see if anything can be observed empirically.
Old 16th June 2009, 11:16 PM   #529
Salas's Avatar
You use long leads so you will probably hear better bass, differentiation and depth. At least that happened when I got it from test phase long cable down to 5cm 1mm2 solid core next to the audio circuit.
Old 16th June 2009, 11:54 PM   #530
ikoflexer's Avatar
You mean that a shorter cable/distance between regulator output and next stage/load improves bass, differentiation, and depth?
OK, so I just tested my theory with a load of 80mA DC + 30mA AC.
Case 1: all sensing components connected directly to drain of Q1 and source of Q4. 20cm cable connecting source of Q4 to a 80mA DC 30mA AC load.
a) scope showed about 200uV ripple on source of Q4
b) scope showed about 2mV ripple on load
Case 2: disconnected all sensing components from source of Q4 and connected them directly to the load with a separate cable of about 20cm.
a) scope showed about 200uV ripple on load
b) scope showed about 2mV ripple on source of Q4
We're talking about a 20cm wire, not even very thin, soldered on both sides! It would be good if someone else double checked this.
Page generated in 0.14163 seconds (64.44% PHP - 35.56% MySQL) with 11 queries
