Go Back   Home > Forums > Amplifiers > Power Supplies
Old 20th August 2012, 03:49 PM   #5261
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Originally Posted by AndrewT View Post
Yes, That's three times in as many days. I going to book myself in!
Do not even think about that Andrew.... We would all loose a crucial source of knowledge.
RC
Old 20th August 2012, 04:14 PM   #5262
but as usual with internet knowledge, one must be capable of recognising if it is worth reading let alone trying to follow.
Will I know if my writings are going down the plug hole, or actually worth reading?
Old 20th August 2012, 04:27 PM   #5263
RCruz's Avatar
You can be sure your writings are read and apreciated.
Not only by me but by most readers that follow your posts for a long time.
We lear a lot from you.
RC
Old 20th August 2012, 04:29 PM   #5264
ichiban is offline ichiban  United States
space charged
ichiban's Avatar
Ditto!!!
Old 20th August 2012, 10:31 PM   #5265
j45yip is offline j45yip  Singapore
+3
Old 21st August 2012, 09:08 AM   #5266
merlin el mago's Avatar
-1
Old 22nd August 2012, 11:36 AM   #5267
judby is offline judby  Denmark
Hi, would you perchance have a reasonable spice model for the 9610 that you're willing to share?
Edit: Sorry, this question was for Salas, who'd told me he'd simulated "my" circuit
Old 22nd August 2012, 11:50 AM   #5268
Originally Posted by Salas View Post
Picture a BJT instead of a MOSFET and its nothing more than the classic ''ring of two'' CCS concept.
Ring of two CCS for differential triode amp - stability?
Sorry for the delay, I was hit by work as my vacation ended. Now recovering from a bike accident I can get some fun done
Regarding the circuit, I was under the impression that Id is dependent on Vgs AND Vds. Looking at the 9610 datasheet I can see that, for -Vds > some 100mV, Id is practically constant given Vgs.
Then it's easy
If Vin increases, initially nothing happens in the FET part. The BJT will have to see an increased Ic - if Vce is constant (=Vgs) then Ic = (Vin - Vce) / (R2 + R3).
In order to increase Ic, Vbe must increase. But here we have exponential dependency so even the slightest increase in Vbe will make Ic increase. Because of this, the circuit is almost independent on Vin.
And one simple obvious way to improve this is to replace R2+R3 with a CCS, then Ic and also Vbe will be constant; the increased voltage drop given increase in Vin will happen over this CCS.
And there can only be one explanation to the strange behaviour I see: instability - even if it does not show up anywhere.
Also, while looking at the 9610 datasheet I must admit, this FET has possibly only one advantage: it's cheap...
Next prototype will probably be 9240 based (got some in my stash now) and with the BJT/FET CCS with R2+R3 (R4 + R10 in the original) replaced with a K170.
Old 22nd August 2012, 12:29 PM   #5269
Even cheaper are the N channel. They perform a bit better. Less capacitance, more transconductance.
Old 22nd August 2012, 12:37 PM   #5270
Noted, thanks
Copyright ©1999-2013 diyAudio
