The simplistic Salas low voltage shunt regulator - Page 526 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 19th August 2012, 10:57 AM   #5251
orelli is offline orelli  Italy
Send a message via AIM to orelli Send a message via MSN to orelli Send a message via Yahoo to orelli
thanks to Felipe and Andrew.
Old 19th August 2012, 11:09 AM   #5252
Originally Posted by merlin el mago View Post
Thick 3 wires primary, thin 4 wires secondary.
thick insulation and small copper area is likely to be high voltage winding tappings.
Thin insulation and big copper area is likely to be low voltage winding tappings.
Merlin:
Your advice/comment is very misleading in that it uses the wrong information to chance upon the correct conclusion.
Better to keep quiet than to make up the science you don't understand.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 19th August 2012, 12:12 PM   #5253
[QUOTE=AndrewT;3132256]thick insulation and small copper area is likely to be high voltage winding tappings.
You are correct Andrew, this si the point!
ps. don't be afraid, I don't kill myself with a transformer.
Arios, Orazio
Old 19th August 2012, 12:29 PM   #5254
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
A picture settles it better.
Old 19th August 2012, 12:33 PM   #5255
Have you connected the yellow wire to chassis?
Old 19th August 2012, 12:34 PM   #5256
That pic clearly tells me that this Rcore has a single primary marked Black/White (Blanc/Noir) for 230Vac duty
AND
it also tells me it is NOT a 3 wire primary !!!!!!!!!!
(I can't read French upside down), but I'll guess the yellow wire is an electrostatic screen that should be connected to Chassis.
AND
finally it tells me it has dual primaries marked Violet/Green and Blue/Red, they are insulated as pairs.
regards Andrew T.
Old 19th August 2012, 12:56 PM   #5257
Salas's Avatar
The yellow primary side wire is ''Ecran electro-statique'' i.e. electrostatic screen to be grounded. I connect that to the mains earth IEC prong and from there I run a wire to chassis ground. You may see a white one bolted to the trafo's bottom right corner.
Old 19th August 2012, 02:40 PM   #5258
I understood, thanks Nick.
Old 19th August 2012, 07:42 PM   #5259
loek is offline loek  Netherlands
AND
AND
You ment Dual Secundairies AndrewT.......
Old 20th August 2012, 08:45 AM   #5260
Yes, That's three times in as many days. I going to book myself in!
regards Andrew T.
Copyright 1999-2017 diyAudio
