The simplistic Salas low voltage shunt regulator
Old 23rd July 2012, 07:14 PM   #5191
euro21 is offline euro21  Hungary
Plot of few 2SK170GR Idss.
Old 23rd July 2012, 08:31 PM   #5192
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
170GR is giving more drift in this circuit than BL. Better the 245A if with GR.
Old 26th July 2012, 07:15 AM   #5193
dtses is offline dtses
tried to match 3 sk170GRs and came out with 4.86, 4.88 and 4.94mA. Soldered them back, turned the reg on, adjusted trimmer to 5vdc output and closed the lid of the case. After about 15min I still got 5.20vdc...weird.
then I put BF245A as Q3, adjusted the legs as it's not pin to pin replacement, same with vdc output and closed the lid...after some 10min I got 4.89vdc it'seems that it's affected vice versa by the heat. Anyway I was unlucky again.
Is there any other suggestions? Perhaps if I use two decent BLs with 7-8mA IDSS as was adviced in some other thread + BF245A as Q3 that would stabilize the output vdc?
Accoring to the manual WM8740 DAC should work fine with +-10% of 5vdc, thus maybe it's not so crucial as it is now?
Old 26th July 2012, 07:26 AM   #5194
Salas's Avatar
Q3 is the crucial component. With BF245A you went off only -0.11V you report. Why not adjust at 5.1V and then let it drift to 5V? Its the LEDs and the Vbe of the BC550 they act in tandem with Q3, and the PPM of the trimmer. Your manual gives 4.5V-5.5V tolerance, in other words why bother for 0.1V?
Old 26th July 2012, 07:31 AM   #5195
Salas's Avatar
And... minus drift is safer.
Old 26th July 2012, 10:22 AM   #5196
Originally Posted by Salas View Post
... in other words why bother for 0.1V?
indeed, it's pretty negligible in this case. I was just wondering why does it happens (thanks for explanation) and why nobody reported the same bahaviour.
yes, thanks again for the help, Salas, and great reg!
Old 26th July 2012, 11:18 AM   #5197
Salas's Avatar
The Leds are diodes, they show negative tempco, a few mV/C each. Its a balance of counteraction with the other semis. At 55C box interior your drift is fine IMHO. This reg isn't designed around a precision voltage reference concept, but around a minimalistic discrete one. We can be very careful about a Jfet type and sample and its zero tempco bias point, the exact drift of the whole system including Vbe & Vgs and the number and type of diodes, Leds etc so to minimize drift, but -0.1V in a hot box it can easily creep in again and its fine for audio purposes IMHO. I am sure all get some drift if they look for it, but you got a hot box interior that others may not. They may be using lower ppm resistors too. Its not a chip to tightly control the spot temperature each semi has anyway, its discrete and biggie with through hole components.
Old 27th July 2012, 12:57 AM   #5198
agussug is offline agussug  Indonesia
My regulator drift from 11.94 to 11.87 in 10 min. and remain stable after that, as I reported earlier in this thread.
Old 9th August 2012, 10:19 AM   #5199
kokonut is offline kokonut  Germany
Default is this a correct interpretation of Salas 1.0 sslv
I want to use this schematic and this pcb for salas V 1.0 with IRF9610,9530 instead of IRF9240 for low current loads like DAC,Clock,Buffer,Phonopre. is this schematic correct for this applications and the pcb design ok? the pcb is from myself and i tryed to get it small as possible for my small chassis. the salas sslv bib is to big for my application. for dirct use i dont need the sensing feature.
thanks for your attention and help
kokonut
Old 9th August 2012, 11:26 AM   #5200
Salas's Avatar
Delete R3, R4, change C5 to 47uF electrolytic, build with both C2, C5, R7. About PCB you got to try it and see.
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
Copyright ©1999-2017 diyAudio
