The simplistic Salas low voltage shunt regulator
Old 15th June 2009, 01:55 PM   #511
Tham is offline Tham  Malaysia
OK. Will build a new cascode and buffer version for the RIAA pre and use the V1 to power my B1 then. Will bypass R1, C1 & C2 as advised.
Old 15th June 2009, 01:55 PM   #512
iko is offline iko  Canada
iko's Avatar
Originally posted by Salas
For normal B1, and to retain Iko's cascode and buffer version's benefits, delete R1, C1, C2.
If you have an input capacitor in your power amplifier or it has DC fault protection, there is a symmetric B1 with incorporated +/- shunts there.
Wow, this is cool! Wasn't even aware of this thread, thanks salas!
Old 15th June 2009, 02:02 PM   #513
I am still trying to voice it...added another 2000uF of filter cap yesterday and more run in... hear fuller bass and more presence in the mid with this additional caps...may end up with 10000uF as suggested .
Definitely photo will be forthcoming.
Old 15th June 2009, 10:56 PM   #514
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
[QUOTE]Originally posted by Salas
[B]We also need to thank James for his PCB efforts.
Here is his latest refinement for V1. He has included every possible nut n' bolt. LEDs CCS, Vbe CCS, positive / negative shunt, Zener socket for changing Vout in a sec, clean, compact, star layout. I did not see anything wrong by looking at it, you may have your second look too. James is more suitable to comment on the options and how to implement them I guess. He has also made a few V1s (not in WWII) and maybe he can convey his experiences and applications if he likes to.
Thanks again for your contribution James.
Hi Salas
I can not relate the connections in the pcb to your schematic... Does the pcb use several layers ?
Ricardo
RC
Old 15th June 2009, 11:19 PM   #515
iko's Avatar
It should use only one layer.
Edit: the component numbering is a bit different than the schematic, since I think James was trying to accommodate both the version with PNP bias for the series mosfet, and the LED biased version.
Old 16th June 2009, 06:07 AM   #516
dodo is offline dodo  Poland
here is the schematic , correleted with the James PCB
Old 16th June 2009, 07:14 AM   #517
jameshillj is offline jameshillj  Australia
Thanks DoDo,
Very neatly done - what program do you make/do the cct diagrams on?
The numbering system is top left to bottom right, just how you read a page - simple method for a simple mind!
Old 16th June 2009, 10:37 AM   #518
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Rs should go from shunt Mosfet's Drain to ground in the schematic, not between Drain and Q3's Emitter, thus breaking the ground. I prefer just a jumper there BTW. Its correct on the PCB.
Old 16th June 2009, 11:12 AM   #519
corrected
Old 16th June 2009, 07:38 PM   #520
iko's Avatar
I'm just wondering if anyone ran into these issues. Let's refer to v1 for now, say you finished it according to the pcb layout above. Now it needs to be coupled to the circuit you're powering. Let's even assume it's not a difficult load so you're not so worried about the output impedance; a phono stage like the salas RIAA draws something like 60mA, and it may vary a very few mA according to the music. Looking at the schematic at the you will see a few components connected to the series mosfet Q1: C2, TZ, J3, Q4, C3, OUT. Let's separate these according to function:
sensing: c2, TZ, J3
shunt action: Q4
filter: C3
load: OUT
Now, in the real world there may be a cable connecting OUT to the real load. Assuming this cable is AWG 18 (regular computer power cable thickness); the cable han approximate resistance of 6.4 mOhm/foot, or 200uOhm/cm. For a length of 20cm we get the equivalent of a 0.002R resistor between the regulator and the load. This cable may be soldered at its two ends, or maybe screw contacts are used. Well, this may add another two milliohms to this "virtual" resistor. What do you think this does to the output impedance measured at the load (i.e. how much does the voltage vary at the IN point of the load, if the current vary)? My simulation shows about 20dB loss in output impedance. And I did not even try for worst case scenarios. Most people probably do not use as thick a cable as AWG 18 for interconnections, right? Thinner cable will have higher resistance.
What to do about this. I have a solution but it's not yet tried in practice. Connect the sensing components with a separate cable directly to the IN point of the load thus splitting the current paths for sensing and shunting. Now the sensing components will try to control the shunt mosfet so that it regulates that point. In simulation this restores the output impedance to its previous levels. Pretty neat, eh?
Note: the transformer DCR (internal resistance), cable type, thickness, and soldering/crimping will be of major importance if the regulator feeds a larger load, such as a gainclone, or class D. Beware then of any resistance on the path going back from the load to the transformer/rectifier.
The simplistic Salas low voltage shunt regulatorHide this!Advertise here!
